Thread: What kind of testing kit is recommended
    What kind of testing kit is recommended to test for all these components? We've never had all these "supplements" recommended to be tested.
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: What kind of testing kit is recommended
    Welcome to tfp, rowdy1
    See this pool school article: http://www.troublefreepool.com/pool-...kit_comparison Many of us use the tf-100 since it is the best value (user duraleigh, the seller of that kit also owns this forum).
    Butterfly's Avatar
    South Carolina
    10,045
    Quote Originally Posted by rowdy1
    Welcome to the forum
    Having one of the recommended test kits will put you in charge of your pool.
    You might want to also want to add a speed stir to your list. It makes testing easier and faster. I haven't heard anyone say that they did not like using it!
    You're done SLAMing when:
    Mar 2010
    Spring, TX
    1,082
    Quote Originally Posted by Butterfly
    +1 with the speed stir. I recommend the TF100 kit.
    13,000 Plaster IG Pool approx
    Hayward C5030 Cart Filter
    Emerson 1081 EB653 1.0 HP 1.40 S.F. 3450 RPM
    Pool Calculator, Pool School, TF Test Kits
    Thanks for the replies. I am trying to adjust to this type of forum and apologize if this is repetitive. There isn't a detailed "search" function and looking through 67 pages of topics is well...tedious. Thanks again.
    22,550
    If you look at the lower left of each page you'll see a Google search function. It works better than the forum search.
