Thread: Added PH plus but should have been Alkalinty
    Hello all,
    I took my pool water to my local store and the results showed I needed to add Alkalinity. The reading was 53 and they told me to add 18 pounds. I had thought I had 10 pounds but after adding it I realized it was PH Plus. My PH reading before adding any PH Plus was 8.0.
    Please advise on what should I do. My pool has become cloudy.
    JagMan1964
    George
    32,000 IG
    Salt T-15 Cell
    Vinyl Lined
    Haywood 1.5 HP
    DE
    Solar Heat system
    JagMan1964
    George
    32,000 IG
    Salt T-15 Cell
    Vinyl Lined
    Haywood 1.5 HP
    DE
    Solar Heat system
    30,427
    Re: Added PH plus but should have been Alkalinty
    Start adding muriatic acid 1 quart at a time until your pH gets down into the mid 7's. I have no idea how much that will take because I have no idea of your starting point. Wait 30-60 minutes in between quarts and test each time.
    You need to get some acid in there to lower the PH.
    It would be a huge help if you had your own test kit. Pool store test results are not all that reliable and you need to make an PH measurement after each adjustment to see if you made the change you were intending to make.
    Thank you
    I know I had read somewhere on the site about a test kit that seems to be a great value and works well. Can you help me with that and I will work that into my budget?
    Thanks again
    JagMan1964
    George
    32,000 IG
    Salt T-15 Cell
    Vinyl Lined
    Haywood 1.5 HP
    DE
    Solar Heat system
    AimeeH's Avatar
    Apr 2012
    Columbia SC
    1,869
    TF-100
    http://tftestkits.net/splash-page.html
    It is in the signatures of many here. (Shame on me,not mine yet!)
    18*36*23 true "L" vinyl IG 29,000 gallons. SWG. TF-100 test kit.
    Much appeciation!
    JagMan1964
    George
    32,000 IG
    Salt T-15 Cell
    Vinyl Lined
    Haywood 1.5 HP
    DE
    Solar Heat system
