Thread: Cloudy water with SWGC.
    Pool size: 4000 gallons (15'x42")
    Filter Type: Cartridge
    AG, SWCG Vinyl summer escape pool
    Pump is 700 GPH.
    FC: 3
    pH: 8.5
    TA: 240
    I've just recently switched over to a SWCG, my pool is cloudy and I haven't been able to get it back to clear. I realize my pH and TA is high, my question is how much pH down would I need to put in my pool? Per the bottle it's telling me 24 oz for a 10 gallon pool but my pool doesn't contain that much water. I have shocked it today and it cleared some but not all the way. Any help would be apperciated. Thanks!
    30,431
    Re: Cloudy water with SWGC.
    Your pH test of 8.5 is unreliable. You should get a decent kit based on drops of phenol red. They only go to 8.2.
    You might put in a pint at a time and walk it down slowly. Hard to guess when the initial test is most likely bogus.
    Jun 2012
    Howell, NJ
    977
    After you get a reliable pH number and get it adjusted, you will need to follow the shock process (link in my signature). For that, you will need to know your CYA number. You should get a good test kit, either the TF-100 or K-2006, both of which I believe can be found in my signature.
    John
    7 year old ~13,500 gal 24' AGP with 1.5 hp Proline pump, 150 sqft Pleatco cartridge, filled with well water with pH of about 4.5.
    Wanda the Whale pool vacuum, home made heater, Taylor K-2006
    Cloudy Pool? 1) Order test kit. 2) Follow SLAM
    New to TFPC? Read Pool School a few times, then post questions. PoolMath will help with chemical additions.
    Ok, thanks I will do that and get back with my numbers.
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    Welcome to TFP!
    What are you using to test with? Most pH tests go up to 8.2. If you want to take control of managing your pool, you need a good Test Kit
    Quote Originally Posted by r0manticizem3
    Shocking a pool is a process, not a 1-time addition of a product. Since the pool cleared up some, but not all the way, that is an indication of something organic in your pool. You need to follow the Shock Process, To do that properly, you need to know your CYA level and this goes back to the importance of getting the proper test kit. Otherwise, your flying blind.
