Results 1 to 7 of 7
Thread: test results advise
    test results advise
    Pool looks great and clear, here are my latest numbers,
    ph 7.6
    FC 8
    TA 70
    CH 280
    CYA 65
    Salt 3200
    Borax approx. 50
    temp 86
    Leave it alone or should I raise the CYA a little, I do have some liquid left over? Florida pool gets full Sun.
    Thanks all.
    13000 in ground Wet Edge Satin Tahitian Blue, Pentair VS pump, Hayward DE4820, Hayward Vac, Pentair SWG IC 40, Pentair Intellibrite 5G, Intellibrite Controller,
    TF-100 Test Kit, Seminole, West Central Florida
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,074
    Re: test results advise
    I'd leave it alone. Maybe turn the SWG down a notch. No need to work it to death.
    Its on 80% I will take it to 60 now, thanks Richard. Leave the CYA alone or raise it a little?
    30,432
    Perhaps raise it but not much....do not exceed 80. Your call......I would leave it if it were my pool.
    Richard320's Avatar
    Jan 2010
    19,074
    Quote Originally Posted by roth79
    How confidant are you on your test results?
    CYA is always iffy but tf-100. checked it twice, 65ish.
    Jun 2011
    Long Beach, CA
    2,790
    I would test it again in a week to see if it changes. If it repeats in a weeks time, you could bump it up. You are close to ideal, so there is no need to adjust it now.
