Thread: Pump info....
    DMAN11's Avatar
    May 2008
    Baton Rouge, LA area
    95
    Pump info....
    Our setup for our new inground vinyl (16X32, Not sure of gallons??) comes with a 1hp Hayward Pump. I have heard alot about getting a 2-speed pump instead of just a 1 speed to help save on electricity,,,,which I am all for....
    My question is this, if I do get a 2 speed pump, do I still need a 1hp, or should I look to get something like a 1.5 hp to have the extra juice on the low setting? OR will a 1hp w/ 2 speeds be sufficient? I have seen posts mentioning a Hayward Northstar 1.5hp 2 speed. Would tha be good for our size pool?
    Also, we are wanting to add a small waterfall water feature later on, will this same "main" pump work for that, or will we need to get yet another pump?? (1 for pool - 1 for Polaris 280 - 1 for waterfall ??)
    I also have read alot of posts about automatic pumps or variable pumps ? like intelliflo that I think is Pentair? but does Hayward make something equivalent? what about others?
    Thanks,,,,
    DMAN
    17,500g ; 16X32 Inground Vinyl
    Hayward 1hp ; SWG
    3/4hp booster on Polaris 280
    WHO DAT!
    GEAUX TIGERS!!
    Mod Squad JohnT's Avatar
    SW Indiana
    9,198
    Normally you don't upsize when going with a 2-speed pump. The idea is that the lower speed can handle your circulation and filtration at a lower cost per gallon of water than the higher speed, while you still have the high speed for cleaning or recovery from very dirty water. Since you have a booster pump for your cleaner, you don't need extra pump for cleaning.
    The flow required for a waterfall is very specific to the particular installation. It would be hard to guess at your pump requirements. Most waterfalls need almost constant circulation to avoid pools of unsanitized water.
    Hayward makes the TriStar Energy Solution™ Variable Speed Pump & Control. It is new this season. I haven't heard of anyone who actually has one. There is also Ikeric.
