Thread: Pool Calculator Page - Effects of Adding Chemical Section
    Jul 2012
    Caddo Mills, Tx
    33
    This section is missing a choice for 8.25% bleach in the dropdown. It has 5.25%, 6%, and then jumps to 8.25%.
    Maybe this could be added? I have 8.25% chosen up in the top of calculator, so if this is why it isn't showing up in the botto section, please forgive me.
    Thanks to the creator of this site and all those experts who regularly post on the site.
    Shawn
    14,362 gallons - Intex Rectanglar Ultra Fame 32'X16'X52" ABG
    Model SF20110 Intex Sand Filter Pump (Max Working Pressure 50 PSI, Max Flow rate: 2650gal/hr)
    With An Intex Krystal Clear SWG Model CS8110
    Caddo Mills, Tx (20 miles East of Dallas...temps low 20s to 110)
    [b]July 19, 2012 Intsall[/
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    Re: Pool Calculator Page - Effects of Adding Chemical Sectio
    Yes, you are right. But the 8.25% you input at the top will still calculate the appropriate dose of chlorine for you pool based on your current test results and desired target FC.
    I was hoping it could be added to the drop down as well
    29,000 gallon irregularly shaped in ground pool. Plaster. DE Filter. 1 hp pump. Pool approximately 10 years old. Polaris 380 robotic cleaner. Middletown, Delaware.
    I have a copy with 8.25% bleach here.
    Jul 2012
    Caddo Mills, Tx
    33
    Thanks Jason!
    Shawn
