Thread: Gas Heater not coming on after Andrea
    I have a Hayward Gas Heater, model H400FDN, which has been working fine since we opened pool this season. After the torrential rain and wind from Andrea, it is not working today - no lights, no sound, nothing. Thoughts?
    36K inground, Hayward 450SF Cartridge Filter, Hayward 2HP Pump, River Rok Granite Pebble Finish, soon to be SWG
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    Re: Gas Heater not coming on after Andrea
    Sounds like the igniter and/or other components may have gotten wet, especially after a storm like that. I had a similar problem with my gas heater when I first moved into our current house. After a significant rain, the heater would not operate. After things dried out, then it worked fine. I then got a cover for it and that solved the problem.
    ps0303's Avatar
    Jul 2011
    FL
    3,695
    Have you checked to see if a breaker is tripped?
    Paul
    http://www.gastekservice.com A word of caution: When working with gas and electrical you might want to consider a licensed contractor. Consider the value of your life and others around you. If you would like to provide a review of the help I provided, please use the following link to leave a review. gastek - Google Search,
    Thanks! It did just need to dry out - by evening it was working fine.
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
