Results 1 to 8 of 8
Thread: opening pool for season--water gushing out of heater
    Opening pool for the season/pumping water from cover, etc. Water is gushing out of the heater. It's a Hayward. This has never happened before...help!
    Jun 2012
    western NY
    1,559
    Re: opening pool for season--water gushing out of heater
    We will need a little more info...
    Is the piping hooked up to the heater both inlet and outlet?
    Was the unit properly winterized to prevent freezing?
    Unknown make 18' above ground (bought used in 1999) Sparco sand filter. Hayward 100,000 BTu heater. 2 speed pump
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,984
    Gushing out where? Perhaps someone omitted an O-ring on a coupling, or forgot to reinstall the drain plug?
    Oh - and welcome
    Smykowski's Avatar
    Sep 2011
    3,065
    Do you have an exact model number?
    If its an H200/250/400 series, there are two plugs on the manifold that need to be replaced before you open up the plumbing.
    Okay identified the problem. Took off side panel. There are 4 copper(?) u-shaped pipes. One of them has burst during the winter and has a 3/4" tear in it. Now what to do?? Is this repairable or is it a goner? I can't figure out how to post a picture or I would.
    Richard320's Avatar
    Jan 2010
    18,984
    Probably looks like the pictures in this. opened-the-pool-today-and-found-a-leak-in-the-heater-t60821.html
    A 3/4" tear is too big to just blob up with solder. A new heat exchanger probably costs the same as a whole new heater.
    Jun 2012
    western NY
    1,559
    3/4" sounds pretty big. I did fix one like that a few years back. Told the owner "no guarantees". Still holding as far as I know.
    I would suggest, if you can get it out, to take it to a radiator repair shop and see what they say.
    Can you post a picture?
    hawkeye's Avatar
    davenport,iowa
    118
    Id fire the pool guy.......try to blow system out with a air compressor this fall when u close that baby......be careful with it though
    18ft 52in deep doughboy 8000 gallons
    22 in sand filter
    1 1/2 pump
    tk-2006 test kit that rocks!
    12.5% chlorine
    aqua critter vac
