Results 1 to 9 of 9
Thread: First time using test kit
    nate81's Avatar
    May 2013
    Raleigh, NC
    190
    I filled my pool from a well, so i didnt test for FC...i'm assuming there is none.
    I tested my pH and it was so low it didnt register....i'm assuming 6.x
    TA i got 20ppm
    CYA i'm gonna guess 0. The black dot never disappeared and I've yet to add anything to my pool, other than the 120lbs of salt last night.
    My pool has 5,000 gallons or so, (website says 5,061) with a SWG so i think my goal CYA is about 70...the pool calculator says to add 47oz by weight of stabilizer. It also says to add 49 weight ounces of baking soda...bu to raise my ph its saying to add 4,275oz of borax??? first pool here...but 267 lbs of borax seems a bit much....help?
    wait...i put pH as 0....but its not 0...but i cant read it with my kit...do i just assume 6.x and add a single pound of borax?
    Intex 16'x48" Ultra Frame
    Intex 2,650-Gallon Sand Filter Pump
    Intex Krystal Clear Saltwater Filtration System
    Taylor K-2006
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,995
    Re: First time using test kit
    Quote Originally Posted by nate81
    TA i got 20ppm
    Fix the TA first - aim for about 60 - and give it an hour or so to mix well, then retest pH. If you're still below the scale, just enter 6.8 and dose accordingly with borax. Give that an hour or so to mix well, then test it again. Repeat until pH is about 7.5.
    You will have no CYA unless you put it there. It's not a naturally occurring thing.
    You also need to put bleach in before it turns green. Once it's balanced and stable, then worry about salt and turning on the SWG.
    nate81's Avatar
    May 2013
    Raleigh, NC
    190
    Quote Originally Posted by Richard320
    So on the pool calculator, just enter CYA as zero and my goal is about 70 and follow that? 47oz of stabilizer for my 5,000 gallons of water?
    Also, is it same to assume that the FC is 0 since i've added nothing to my water yet?
    Taylor K-2006
    Richard320's Avatar
    Jan 2010
    18,995
    If that's what it says!
    We advocate 1) filling an old sock or nylon with the granules and suspending it in front of a return
    2) Aim a little low in case your pool isn't as big as they say it is. It's easy to add more later, but only goes away with draining.
    Jun 2011
    Long Beach, CA
    2,784
    You are using the calculator correctly.
    Your fill water should be 0 FC since it is coming from a well.
    nate81's Avatar
    May 2013
    Raleigh, NC
    190
    Thanks Richard and Ping
    one more question, do i need to get shock first or get pH correct, and then shock?
    Taylor K-2006
    30,419
    Get your pH into the 7's first. Then don't "get shock" but initiate the "shock process". It's VERY different
    read "How to Shock Your Pool" up in Pool School
    nate81's Avatar
    May 2013
    Raleigh, NC
    190
    typo I was going to type get the bleach in the pool. I'm going to use 2 gallons of bleach (from calculator) after I get my ph up...but do i need to be checking my CF after I raise my ph or will there be no affect?
    Taylor K-2006
    Richard320's Avatar
    Jan 2010
    18,995
    pH doesn't change FC. High FC can mess up pH test. That's why we say fix pH first.
