Results 1 to 9 of 9
Thread: Salt water tests for the SWG
    Hi there, I have been reading about the strips, the drop tests and the electric systems. What salt level tests do you guys use and what has worked out best for you. I dont mind the cost as long as its acurate and easy to use. Thanks a ton
    Intex 22 x 52 Ultra, Intex 16" Sand/Saltwater combo
    ComputerGuyInNOLA's Avatar
    Oct 2012
    Mandeville, Louisiana
    604
    Re: Salt water tests for the SWG
    I think the strips are inaccurate. I use the Taylor K-1766 test kit. I also have the Safedip electronic meter but rarely use it. It does not seem to be very accurate because the results varied too much.
    Gunite/Plaster pool at 13k gallons. All Jandy with CL340 series cartridge filter, 1.5 HP Jandy Stealth pump. Jandy 1400 SWCG and PDA4 controller. Dual waterfalls. Polaris 280. Pool installed August 2012. Southern Louisiana. And lets not forget my trusty TF100 test kit!
    Jamison04's Avatar
    Jun 2011
    Tecumseh, OK
    573
    Taylor K-1766 test kit here also. I prefer drops to strips.
    24'x52" Artesian w/ Portifino liner - Hayward 1hp powerflo matrix w/24" sand filter - AquaTrol RJ SWG. Solar heating to come. -
    May 2009
    Trenton NJ
    497
    I always had good luck w/ strips.
    20,000 gallon viking fiberglass pool w/aqua comfort heat pump, pentair whisperflo pump 1.5hp autopilot dig-220 swg w/RC42 cell (42,000), pg2000 fiber optic lights
    hayward sand filter(medium is echoglass)
    Blue diamond robot cleaner
    Hi we have an Aqua-Trol SWG on our pool. Are you all recommending that we also test the water separately even if the Aqua-Trol give and electronic reading on the diagnostic box? Thanks.
    Oct 2012
    604
    I always test mine manually. My new Jandy Aquapure shows one reading, say 3200 ppm, and a totally different reading, say 3600 ppm the next time I turn on my remote. Not very accurate.
    Jamison04's Avatar
    Jun 2011
    Tecumseh, OK
    573
    Yes. Our aquatrol shows 3200 but the drop test result is 3000.so there is a marginal difference between the two minutes the end it only matters what the generator thinks it actually is. As long as it's reading and your reading are close than you shouldn't have any issues.
    bobodaclown's Avatar
    Apr 2011
    Murrieta, CA
    2,360
    Aqua Check Salt Water Strips been happy with them.
    Aqua Trol display says 1900, pool store test (I know) says 2300. Doesn't really matter. If the AT says 1900 it will not generate. The testing number is close as I can tell by the tase of the water. My question is how does the AT unit compute the salt level? Is there a sensor in the generator or flow switch that determines the salt level displayed? Will a cell that is going bad give an inaccurate reading? Might be looking at a new cell if this one won't clean up, it looks to be OK but I will clean it again. In the meantime the pool is starting to turn greenish, so let the bleaching begin until I can get an accurate reading on my salt level displayed.
    Trenton, IL (St. Louis Area)
    TF-100 test kit, 18,000 gallon, 18x33 oval Johnny Weismuller, AG, Jacuzzi Lazer sand filter, AquaTrol SWG, 1.5 HP Pentair pump that runs constantly.
