Thread: Want to Submerge a hot tub. Suggestions Please
    We have been enjoying our inground pool for 4 years now, and now we have an extensive seawall replacment that has to be done. So while the back yard is tore up AGAIN We are considering pouring another elevation of patio with a built in Bon Fire pit. While we are working with the cement I would like to form up a vault to recess a hot tub. Any thoughts or suggestions? Are the hot tubs a standard dimension? What is a quality manufactuer? Thanks in advance,
    17,000 gallon IG Humpback Kidney
    333k Sta-Rite Max-e-therm Heater
    Sta-Rite Modular Filter
    Intellichlor IC-40
    Awesome Tiki Bar!!!!!
    bmoreswim's Avatar
    Jul 2012
    Central MD
    3,798
    Re: Want to Submerge a hot tub. Suggestions Please
    Don't you need access to the sides of them for getting to the pumps/ motors?
    18'x38' Rectangle (3'-8 1/2' deep w/ diving board) - 27K gal. w/ gray plaster
    Hayward equipment (cartridge filter, 2-speed pump, SWCG, automation) View Our Build
    Coverstar automatic pool cover | StoneMakers concrete retaining wall and decking | Merlin SmartMesh winter safety cover
    Spring 2013 Build | Dolphin Active 20 robot cleaner | Support TFP!
    Swampwoman's Avatar
    Apr 2012
    Grand Rapids, MI
    3,765
    Yes, you sure do, unless you're installing a sunken structure that runs off your pool equipment or is deigned to have the pump and controller(s) located on the equipment pad. While lots of folks deck out to partly surround the stand alone models, I don't think that type would be suitable for a concrete vault unless you left a generous work well for the pump, heater, and circuit board.
    So you'd probably want to plan out the installation based on the tub and equipment you choose or have built right in rather than the reverse. Likewise, you'd ave to address drainage, as I don't see any logical way for a concrete surrounded tub to drain n less you connect a built-in drain that connects to another system.
    IMHO, the disadvantage of a concrete surrounded hot tub might be the rehab cost when fixing inevitable leaks etc. years hence. On the other hand, that's what we do for pools, so if you take the pool approach and just build an "inground" structure with all the appropriate infrastructure and tie it into you system you'd likely be golden.
    I have a Jacuzzi brand stand-alone that's been running for a million years (17 that I know of.) I did have to change out the pump last year, and the life expectancy on the 2 hp is typically about 15 years. Other than that, she's only ever required a pressure switch and a bit of tinkering here and there, so I'd give jacuzzi a thumbs up for longevity.
    In ground vinyl Grecian, 24k gal, Hayward 220t sand filter, VGreen VSP 165, Hayward SWG, Raypak NG 265k heater, dolphin m4.
    Helpful Links:
    GET A TEST KIT Chlorine/CYA Chart How to SLAM About Metals & Stains
