Thread: Ideas about a leaking drain cap
    We just filled up our pool this year and there's a slow leak from the drain cap. I saw on the internet I can get replacement drain caps, but not sure if I'll be able to get it on with the pool full. I tried putting something firm under the drain for counter-pressure, but that didn't seem to help. Any suggestions or ideas?
    IG vinyl 26,000 gal., Hayward S-200 sand filter, Hayward HP600 heat pump
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: Ideas about a leaking drain cap
    Welcome to tfp, lbslott
    You should be able to block the hole from the inside with a bucket or a flexible peice of rubber, etc...to slow down the leaking so that you can change/fix your plug.
    Is yours a screw on type? If it is, I would try some teflon tape on the threads before replacing it.
    Yes, it's a screw-on type. I've never heard of teflon tape, thanks!
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    It is the same tape used to seal general plumbing threads.
