Results 1 to 10 of 10
Thread: Adding DE
    Whatrymes's Avatar
    May 2011
    E. Bridgewater, MA
    132
    Adding DE
    Am I missing something? I have a DE filter below the water line. I have a cat walk around the pool which blocks access to the top of my skimmer. How do you add DE after a backwash going through the skimmer door?
    15 X 30 X 3.6 Ester williams AGP
    10,800 gallons
    Haywood EC40C90 DE filter 1 HP pump
    TF-100 Test Kit
    38,271
    Re: Adding DE
    How do you empty your skimmer without access to the basket?
    I guess you would just have to try to pour the slurry in through the front .... maybe with a funnel of some sort.
    Why not add a trap door you can open to access the skimmer properly?
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Re: Adding DE
    What is the cat walk made of ? You need access to the skimmer lid. That's going to be tough going thru the skimmer weir. You probably won't get it all in the filter.
    Jeff
    Whatrymes's Avatar
    May 2011
    E. Bridgewater, MA
    132
    Re: Adding DE
    I have to reach in the pool and pull the skimmer door open, a real pain when my pumps chuggin' along.
    I've thought of the trap door and I do add the slurry through the front. I thought maybe there might be one of those trade secrets I haven't thought of available.
    10,800 gallons
    TF-100 Test Kit
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Re: Adding DE
    + 1 on the trap door.
    Jeff
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Re: Adding DE
    Personally I would try rigging some of of funnel and slurry for now, maybe cut the bottom out of a bleach jug
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Re: Adding DE
    All in all, it's sounds like a real PITA without the trap door.
    Jeff
    harleysilo's Avatar
    Mar 2012
    North Georgia
    1,924
    Re: Adding DE
    I tried that once and got de all over my pool, dang mess I tell you!
    18'x43' Sport Pool
    19,000 Gallons Vinyl Liner 3'-3.5'-4'
    SWCG and D.E. Filter
    Test Kits - Pool Calculator - Chlorine/CYA Chart - Pool School
    Secret Weapon for Pool Chemistry Testing
    38,271
    Re: Adding DE
    I seem to make a mess even just pouring it into the top of the skimmer
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Re: Adding DE
    I hear ya jblizzle ! What I've been doing is measuring the full amount out then put it in a bucket and use a wooden spoon to slowly slide it out into the skimmer.
    Jeff
