Thread: CYA and Bacteria
    CYA and Bacteria
    Another day, another random thought......
    We've heard stories and seen evidence of people's CYA disappearing over the winter, and I think I remember reading that it was due to some sort of bacteria eating the CYA.
    Is there anymore known about this? What if...someone could identify the bacteria and intentionally put it in a pool with high CYA - as an alternative to drain/refil?
    I know, probably isn't practical, but is it possible?
    23,000 IG Plaster pool w/ spa, Pentair FNS Plus 48 DE Filter, Hayward RS1000 Main pump, Polaris booster pump, CPSC48 SWG, Legend pool sweep. Dallas, Texas, Full sun, Taylor K-2006
    38,301
    Re: CYA and Bacteria
    We have often joked that someone could become a millionaire if they figured out how to do this.
    One issue is that while it reduces the CYA, it also generally raises levels of other undesirables, like ammonia, which then requires massive amounts of chlorine to remove. So ... would it be cheaper to buy a product to add and then buy a lot of chlorine to remove the ammonia/CC ... or to just replace some water ???
    Mar 2007
    San Rafael, CA USA
    12,082
    See Degradation of Cyanuric Acid for technical details. Unfortunately, there isn't an easy way that we know of to control the bacteria so that they degrade the CYA all the way to nitrogen gas rather than stop at ammonia. It's related to the types of bacteria and whether the conditions are aerobic or anaerobic.
