Results 1 to 11 of 11
Thread: Pebble Sheen Finish Wears Out Polaris Sweep Hose Scrubbers
    Apr 2009
    Northern Virgina
    55
    Last summer I replastered my 30-year-old pool with a Pebble Sheen finish and have been very happy with the results. However, one unanticipated result is that the rougher texture of the Pebble Sheen finish causes the sweep hose scrubber on the end of my Polaris 280 to wear down more quickly. This year, I replaced the tail of the sweep hose with an attachment called the AlgaeBlaster. It basically has three small holes drilled into the side which allows water to shoot out and scrub the plaster instead of using a sponge-like scrubber. I can't vouch for the claims the manufacturer makes about improved cleaning efficiency, but it does eliminate the need to buy replacement scrubbers. I haven't seen a lot of discussion about the AlgaeBlaster on the forum, so I thought I'd share my experience with it.
    22k gallon IG Anthony free-form pool and spa with PebbleSheen finish, Pentair WFDS-8 WhisperFlo Full Rated Dual-Speed 2HP pool pump, Sta-Rite S8D110 System 3 Grid D.E. 53 sq. ft. pool filter, Raypak R406A 399K BTU cupro-nickel propane heater, Polaris 280 pool cleaner with 3/4 HP PB4-60 booster pump, Goldline Aqua Plus controller and SWG, Inter-Fab G-Force pool slide.
    tcat's Avatar
    May 2012
    Austin, TX
    735
    Re: Pebble Sheen Finish Wears Out Polaris Sweep Hose Scrubbe
    I have the same finish. I went through maybe 2 or 3 "scrubbers" last season. Decided to buy a robot this year and keep my pressure cleaner as a back up. The nozzle idea sounds good, if the tail doesn't swing out of the pool... I'm surprised they don't make a tail that has bristles all the way around and down it; now that would scrub!
    IG pebble, 15,000 gallon
    48 PentAir DE Filter with backwash valve
    PentAir Whisperflo pump with 1hp 2-speed motor
    Aquabot 4WD, Poolskim
    Intermatic Dual Timeclock with freezeguard
    DIY chlorine feed
    BBB
    Missouri City, TX
    73
    Jim -
    I have the same issue with my Polaris. How does the AlgaeBlaster work?
    Steve
    20,000 IG WetEdge Satin Matrix Northshore Plum, Filled 8/24/12
    Apr 2009
    Northern Virgina
    55
    The three holes drilled into the outside of the AlgaeBlaster allow water to shoot out of the holes when you attach it to the end of your Polaris tail. This allows the tail end to "float" above the plaster, which keeps it from scraping the finish and wearing down. The water jets act like mini pressure washers to loosen dirt and algae from the plaster instead of the scraping action of a tail sponge. There's a picture of it on their website: http://www.algaeblaster.com/
    Vector's Avatar
    Mar 2014
    Southwestern IL, United States
    12
    Re: Pebble Sheen Finish Wears Out Polaris Sweep Hose Scrubbers
    i have the same issue. i have a Pentair Racer, and the tail scrubber is done. Pool guy wants $22 for one of those little pieces of foam.
    Jul 2013
    Carrollton, TX
    40
    14,000 gal IG + spa, DE Filter, 400k BTU heater, Polaris 280, Aqualink RS6, TF-100 Test Kit
    30,478
    I only have robot experience but I would think it would actually be advantageous to have those scrubbers touching the pool surface.....even if they do wear down rather quickly.
    Much like spraying your car clean or wiping it with a rag, that physical touch to the surface would seem to do a better job. $22.00 a pop would get my attention, though.
    Apr 2009
    Northern Virgina
    55
    Just to follow up on my original post, the AlgaeBlaster lasted for five months of daily use and was finally wearing down to the point where I replaced it. It's now about $20, so going with the original scrubber sponge may be more cost-effective at 5 for $10. I didn't notice any significant difference in cleaning ability between the AlgaeBlaster and the sponge, so I may go back to the sponge when the AlgaeBlaster wears out again.
    GDN's Avatar
    Oct 2016
    Dallas, TX
    308
    I've got a Pebble sheen finish and a Pentair Racer - 14 months old now - the scrubber on the end of the hose has no wear on it at all. Love the Pebble Sheen finish, but others complain, maybe some are finished smoother than others?
    Greg -
    11K gal, IG Pebble Sheen (Aqua Blue) with sun ledge and attached spa, Pentair Intelliflow 3050 VS/SVRS (3HP), Pentair ET 8 with Screen Logic, Pentair Racer with 3/4 HP booster pump, 400KBTU Pentair Mastertemp, Pentair 60 sq ft DE filter, J&J Intellibrite LED in spa, Zodiac Nature 2 (not used), Stenner pump/liquid Chlorine, build completed in August 2015
    Mar 2015
    Sugar Land , TX
    428
    Quote Originally Posted by Vector View Post
    I took the tail off my racer and it cleans just as good or better. All the tail seemed to do was stir up the dirt off the bottom, thus keeping the racer from going over it.
    8500 gallon IG Pebble Sheen with Spa. 3hp Pentair VS Intelliflo ( pool ), 3/4 hp WhisperFlo ( water feature ),Pentair Racer, 400K Pentair heater, Pentair 500sqft Cartridge filter, EasyTouch 8, Stenner 45mp2 15gallon wired to ET8
    Jul 2017
    dallas/TX
    1
    check this out as a superb alternative!! it was we all were waiting for...
    SWEEP HOSE TAIL SCRUBBER BRUSH for Polaris and Pentair | eBay
