Results 1 to 13 of 13
Thread: Soaking up tanning oil!!
    My wife and friends put tanning oil on when laying out in my pool. The problem is that it is causing my sand filter to clog up thus causing the pool to appear cloudy and slow the pump flow until i backwash. I am having to backwash every 2 days. I read that i could add a few tennis balls to the pool and let them float around. Any tips or suggestions?..
    24x54 Saltwater 8000 (thepoolfactory), Hayward 23" Sand Filter, 1.5Hp 1-Speed Power-Flo Matrix Pump, AQ-TROL SWG, AquaBot Pura 4X
    38,274
    Re: Soaking up tanning oil!!
    Tell them to stop .....
    Tennis balls may help or try the scumballs: http://www.amazon.com/Scum-Ball-Pool-Wa ... B001HDIBKU
    Backwashing may not be removing all the oil/goo that might be accumulating in the filter.
    30,415
    Elavating your FC level to twice what is suggested may help quite a bit. It is perfectly fine to swim at those levels.
    -I doubt i would win the battle by making them stop putting tanning lotion on. Doesn't seem reasonable.. I am looking into those skum balls.
    -Every other day or so I go pour some bleach in the pool to help out.
    I had the same question regarding the tennis balls. Was directed to the scumballs and they seem to work.
    Completed March 1, 2013. 12,500 gallon IG Lagoon Style w/swimout, walk-in steps, 15' x 30' x 3' - 5', Gunite, Wet Edge Technologies, Pebble Sheen - Northshore Tahoe, 2" Tennessee Fieldstone Coping, Belgard Country Blend Pavers, 1.5 HP Superflo, 19" Tagelus Filter, IC-20 SWCG.
    30,415
    Perhaps if you just kept your FC high by careful measuring and dosing, the issue would go away. By far, that's the best fix, if it works.
    I went and picked up one of those aqua ez pool cleaning balls from lowes. Hopefully this helps some. I probably need a few of them...
    cramar's Avatar
    Nov 2010
    Sault Ontario
    1,143
    Buy a speedo or man thong, come out when they are there and start lathering on oil with them....maybe partake in some physical labor around the pool.
    Now, assuming your an average looking guy and said women won't actually appreciate this, make a deal with her that you'll stop if they stop, if not than have a liberating summer in the banana hammock.
    38,274
    Lol I'll let y'all know how that goes.
    Casey's Avatar
    SW PA
    10,438
    I hope your skin loves the sun if you do go that route! I burn, peel and then burn again! My husband on the other hand... he gets dark sitting in the shade!
    Smykowski's Avatar
    Sep 2011
    3,065
    Backwashing every two days is too often; it sounds like there's something else going on besides just tanning oil. Can you give us a full set of test results?
    ComputerGuyInNOLA's Avatar
    Oct 2012
    Mandeville, Louisiana
    604
    Ask them to let it dry before they enter the pool or get a bunch of scum balls. I have read that tennis balls do help.
    Gunite/Plaster pool at 13k gallons. All Jandy with CL340 series cartridge filter, 1.5 HP Jandy Stealth pump. Jandy 1400 SWCG and PDA4 controller. Dual waterfalls. Polaris 280. Pool installed August 2012. Southern Louisiana. And lets not forget my trusty TF100 test kit!
