Thread: what test kit should I buy
    Jun 2013
    Dartmouth,MA
    3
    hello fellow pool owners. I am new to this and looking forward to getting advice. I recently purchased a 18 foot round above ground pool. What is the best and most reliable test kit out on the market today
    I have a 18' round pool 54" deep Meadows Pool (Namco)8600 gal. Waterway -1 hp motor - Waterway cartridge filter 150SF - Hayward Goldline AQ-TROL-HP Above Ground Chlorinator
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: what test kit should I buy
    Welcome to tfp, chevytruck1214
    See this pool school article for recommended test kits: http://www.troublefreepool.com/pool-...kit_comparison Many of us have the tf-100 because it is the best value (the seller of the tf-100 is also the owner of this forum).
    cramar's Avatar
    Nov 2010
    Sault Ontario
    1,143
    I own the Talyor K2006, it's a great kit but more than I need, that said I'd go with the the TF-100, it's tailored to what you need.
    Quote Originally Posted by chevytruck1214
    I use the Talyor K2005, easy to use. Seems accurate as compared to what my pool shop results are. They use Taylor regents as well, although I didn't buy it from them and they mark up the regents brutally .... so I buy direct, when replenishing.
    Maybe, choose your kit based on ease/cost of regent replacement ??? The TF100 uses Taylor regents so I expect both are equally accurate. Avoid the cheap sets from walmart, small shops, etc .... they may have been on the shelf for 5 years and be useless anyway.
    KC
    KC in Ottawa, Ont. Canada........62.5k L(16.5k us gal) IG Vinyl Pool. 18 x 32 Odysee II. Hayward S270T sand filter and 1.5hp pump. Zodiac Duo Clear 130 Salt System(up to 130k L), Raypack Digital Pool Heater.
    38,246
    The key to a good test kit is the FAS-DPD chlorine test ... it is more accurate and will read much higher levels of both FC and CC.
    FYI, The K-2005 is lacking this test and thus the reason we recommend the K-2006 or the TF-100.
    cramar's Avatar
    Nov 2010
    Sault Ontario
    1,143
    Dittos to Jblizzle, whatever test kit you get it HAS to have the FAS-DPD test, absolutely.
