Thread: CYA & Fiberglass Pool help guy with OCD
    May 2013
    North East Ohio
    959
    So, I have been reading and reading and reading and I get 99% of The Pool School.
    I just have one follow up to verify my thought process.
    My CYA is currently approx. 20 - water is nice and clear, etc. According to what I read I need to bring it up to approx. 30 - so working on that slowly.
    The range is 30-50 of CYA - and thus I understand the corresponding FC levels.
    To a layman, it seems that a CYA of 30 would allow me to keep a lower FC level and still have awesome water. What is the down side of staying at 30 ? Is it just the SUN will eat my FC faster than at 50 and I will have to inject more bleach to keep the TARGET FC where needed, etc.
    Is my Pool Schooling thinking accurate ?
    Thanks again!
    14,750 GAL IG Fiberglass (16 x 33) NE Ohio || Jandy 1HP 2 speed Pump || Waterco MultiCyclone 16 Centrifugal pre-filter (removed due to not working with sand filter) || 30" 575 Lb. Sand Filter || AquaCal 140K BTU Heat Pump || Solar Cover || Inter-fab Adrenaline Slide || GLI Monsoon Solar Cover Reel || K-2006C Test Kit || BBB with Liquid Chlorine Stenner Injection || Rayner Mighty Mesh Winter Cover
    38,290
    Re: CYA & Fiberglass Pool help guy with OCD
    Quote Originally Posted by toofast
    This is exactly right. Even though the target FC is higher at 50ppm, you will actually end up having to add less FC each day because less is lost to the sun.
    If you do not have strong sun all day, then 30ppm could be plenty.
    Mar 2013
    CT
    351
    Good question!!
    I'll be interested to see the answer.
    16 x 32 In-Ground vinyl, 21,000 Gallons, Hayward Cartridge Filter, Hayward Tiger Shark robotic cleaner, Taylor K-2006 Test Kit
    38,290
    Quote Originally Posted by dschribs
    Good question!!
    Was my previous answer not good enough
    May 2013
    North East Ohio
    959
    Good enough for me...thanks again!
    4knights's Avatar
    NE Kansas
    419
    Good question!!
    They were probably typing when you answered, your answer posted first.
    Ron- Kansas. IG fiberglass, Riviera 30 Freeform 13600 gallons,
    EasyTouch 4 w/IC20 SWCG, Pentair Whisperflo 1hp, 2 speed 220 pump, Hayward ProGrid 4820 DE filter using Eco Klean instead of DE, 2 Savi Melody 12v 5 color LEDs, Raypack 266k btu millivolt heater, Arctic Armour Mesh custom safety cover (Total self Install) TF-100 test kit w/Magic stir.
