Results 1 to 7 of 7
Thread: Test results-please recommend
    Here are my numbers after replacing about 30% of the water. I have a gunnite bottom and fiberglass walls that have been coated with epoxy paint. Approx. 24000 gallons, sand filter.
    Free chlorine: 4
    Combined chlorine: <.5
    PH: 7.4
    alkalinity: 100
    CYA: 35 (was 80)
    hardness: 90
    temp: 75
    I believe I need to bring up my alkality and hardness. If so, what should my goal be and is there a non-pool store product that I can do this with?
    Please make any recommendations you see fit.
    Thank you so much,
    Mike
    Those numbers look good to me!
    Your alkalinity (TA) is fine where it is. And there is no reason to bring the CH level up (unless you have a spa you forgot to mention).
    Remember to keep FC around 3 to 7 and never below 3.
    Gunnite bottom needs Calcium??
    8200 gallon 20' x 48" round vinyl frame pool,
    Intex SWCG, 12" sand filter, 1600gph pump, TF100 test kit
    Quote Originally Posted by The Mermaid Queen
    The epoxy paint should have sealed the gunite, so there isn't any exposed plaster or concrete, so no need to add calcium.
    Sorry, maybe I misread... thought only the walls had been coated... Just trying to earn my keep 'round here!
    Guest
    I get the same impression as TMQ, that the bottom is gunite and the walls painted fiberglass.
    mjt123, if the gunite is not painted you need calcium. With exposed gunite calcium hardness should be between 200 and 300.
