Thread: used tf100 kit fir first time
    May 2013
    Arizona
    112
    Here r current readings
    Chlorine 3.6
    Ph 7.8
    Ta 150
    Ch 180
    Now the cya test i never saw the black dot go away stayed their visible till cylinder was filled to top and still saw the dot...
    24x52 uf intex..using bbb method...running the 2500 size b cartridge system till next wk. Changing filter cartridge today..
    Pool calculator says addd 19 oz muriatic acid and 128 oz of calcium chloride...do i need a pool supply store for those two and should i wait to add those things till i run filter tonite. I run eight hrs about 9:30 when we r done night swimming. Current levels ok for son to swim in today?
    Feb 2008
    Denton, TX
    5,061
    Re: used tf100 kit fir first time
    Moved your topic to a different forum since it didn't belong in the outdoor kitchen forum.
    Yes, adding acid to lower your pH a little is fine. Have you added CYA at all yet? I'd add enough to get you to 30 but don't retest it for another week since it takes a while for the CYA to fully dissolve.
    Since you have a liner pool, you don't need to increase your CH as it isn't necessary in vinyl pools.
    Based upon those suggestions, the pool water chem readings should be ok for swimming. Just don't let him get in until newly added acid has had a chance to circulate for 30 minutes to and hour.
    May 2013
    Arizona
    112
    I havent added any cya yet at all...think ill wait till tonite to add acid and run filter...thnks for answering sorry put in wrong spot awesome kit much more accurate good investment
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Definitely get the cya in there. That's the sunscreen for your FC. Without it you'll lose all your FC and then your asking for algae to set up shop.
    Also adding cya will also lower ph.
    Jeff
