Thread: (Fairly) slow leak
    (Fairly) slow leak
    I need help. We have a 15'x48" Intex metal frame pool. Last year was great, we were newbies, made some mistakes (not totally level), but all in all a great experience. Took the time to level out area, put in border stones, laid a bed of sand, got the pool out and up, and lo and behold, we apparently have a leak. Only got a couple of inches of water in the pool before we noticed a tiny bit of water pooling around the base of a leg, let it go until there was about a foot of water in pool, and now have water pooling around another leg (the two legs are next to each other), only about 2 cups of water at the most. Have been reading and contemplating...no water on pool walls, so I'm guessing it's on a seam or in the bottom. Advice? How hard is it to find a leak on the bottom? What about these "fix-a-leak" products?
    Apr 2013
    Battle Creek, MI
    298
    Re: (Fairly) slow leak
    Quote Originally Posted by akjung
    I need help. We have a 15'x48" Intex metal frame pool. Last year was great, we were newbies, made some mistakes (not totally level), but all in all a great experience. Took the time to level out are, put in border stones, laid a bed of sand, got the pool out and up, and lo and behold, we apparently have a leak. Only got a couple of inches of water in the pool before we noticed a bit of water pooling around the base of a leg, let it go until there was about a foot of water in pool, and now have water pooling around another leg (the two legs are next to each other). Have been reading and contemplating...no water on pool walls, so I'm guessing it's on a seam or in the bottom. Advice? How hard is it to find a leak on the bottom? What about these "fix-a-leak" products?
    The patches with the special glue do work, but you could be searching for a while. Our first Intex ( the blue with white frame) sprang three leaks in the second season after being moved across state lines. Fortunately they were all on one side and could be easily identified. Used a small patch on each one with some glue that works from the inside out under water.
    (By the way, "Old Blue" has been retired in favor of the new Ultra Frame. Good luck.)
    18'x4' AG Intex Ultra Frame, 6,700 gal., assembled new 2013; Mods: Hayward EC50C90 Perflex filter & 1 h.p. PowerFlo Matrix pump, Fiber Clear cellulose D.E. substitute, Hayward H100ID1 100,000 BTU NG heater, a pair of 2'x20' Sungrabber solar heaters via the original Intex 635T pump, grey Hydro Tools through-the-wall skimmer, Confer steps/ladder system & Cover Free chemical pool cover. The Summer of Mods!
    [quote="CeeElGee
    (By the way, "Old Blue" has been retired in favor of the new Ultra Frame. Good luck.)[/quote]
    CeeElGee, Thanks for the reply...I guess I'll spend the afternoon crawling around in a foot of water, looking for leaks...wish me luck!!
    Jun 2012
    MA
    347
    I know a guy who used duct tape to find the leak in his pool. He put duct tape down on the bottom of the pool in the suspected area until the leak stopped. He had cleared a small channel under the side of the pool so he could tell when it wasn't leaking. I stopped a leak in my pool last year with a peel off patch for an air mattress. It held all season.
    The dye method would probably work on an above ground pool as well. See this:
    http://www.youtube.com/watch?v=vlQME1qCWjk
    Walnut Creek, CA. 18k gallon Pebble Sheen + 1.5k gallon IG spa, 1.5hp whisperflo main pump, Pentair clean and clear 420, Intellichlor IC20, Polaris 360 w/booster,Jandy lite 2 natural gas, plus solar with Heliomatic 5000 controller and 3/4 hp booster
