Results 1 to 14 of 14
Thread: Party tomorrow chlorine a bit high.......
    Jun 2011
    East Texas
    27
    I finished the shock process and have not added chlorine now for 4 - 5 days. Sunday I think?
    I turned on the SWG yesterday instead of just free flowing. Today I just tested at FC 8.5 no cc. PH 8 TA 170. added acid but do I.....
    A. turn the swg off for the day and see if it drops by tomorrow.
    B. leave swg on and see if it drops a bit.
    C. leave swg on and maybe turn off tomorrow?
    We will be in it tomorrow after noon I'm sure some chlorine will be used anyway.
    I'm wondering just how much too high will bother our skin/eyes, bathing suits and such.
    Current 24' x 52" Intex W/ swg and sandfilter
    12,500 Gal. above ground.
    About to put my big girl panties on
    and get a real pool. :)
    Real pool never happened,,, ripped off. :-(
    TF100, no speed stir.
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: Party tomorrow chlorine a bit high.......
    usually it's a good idea to raise your chlorine a little before a party anyway. If your CYA is at a normal SWCG level, you are fine at 8.5ppm.
    30,432
    What is your CYA?
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,074
    You'll want FC to be on the high end before a party.
    Jun 2011
    East Texas
    27
    FC 8.5
    CC 0
    PH 8
    TA 170? slightly pink but another drop makes it red so 180?
    just added acid to lower been trying to aerate.
    CYA 80. I posted that but not sure where it went..
    What is your cya? As others have posted, if you are within normal cya range for a swg, you are fine to swim at 8.5 FC. It is safe to swim up to shock level, which is in the 20's for normal swg cya values.
    POOL: Intex ultra new in 2014 (32 x 16 x 52) (seasonal; on concrete pad covered with 1.5" extruded or whatever foam insulation sheets - ugly, but comfy); added a through-wall skimmer; I add salt for feel. EQUIPMENT: Pentair SuperFlo pump (1HP, 2SPD); Pentair cartridge filter (200 sq. ft); Pentair MasterTemp natural gas heater (400,000 btu) Climate/Location: Eastern Nebraska
    Richard320's Avatar
    Jan 2010
    19,074
    Quote Originally Posted by wildchilde
    FC 8.5
    CC 0
    PH 8
    STOP!!!
    Your FC level is dependent on CYA level. You cannot say, nor can we, if FC is high without knowing that number!! Full test results are critical. If CYA is 100+, your FC is too low. If it's 10, it's too high.
    Jun 2011
    East Texas
    27
    Is it not showing? I posted it and it obviously disappeared so I edited the last post to add it again. It's at the bottom of the last post. The cya level is 80 but can go out and test it again now to see if it's reading different from last week.
    30,432
    No need to retest. You can swim safely in any pool up to shock value.
    What has not been discussed is your pH which should NEVER be in the 8's. Lower it to the mid 7's.
    I did not see 80 cya before i posted. G to pool school and look at the cya/chlorine chart and you'll see your minimum, target, and shock FC levels for that cya. You are fine to swim at 8.5. Have a great pool party!
    Jun 2011
    East Texas
    27
    NP about not seeing it. I'd posted a separate post then when it didn't show I just edited the other one. The PH is high but I've been aerating to raise it and help bring the alk down. It will in time....
    Thanks!
    38,540
    You realize that aerating does not lower TA right? Since you have got the pH up to 8, time to use the acid to lower the pH and the TA down.
    Jun 2011
    East Texas
    27
    But don't you naturally raise the PH by aeration which does not raise the TA, then add acid which lowers them both and keep going until the desired levels? Like if I get the ph to say 8 and my ta is 60 but i add acid and it lowers the ph to 7.2 and the ta to... whatever it would be... then repeat the scenario until the ta is down to where I want it to be? Or have I completely misunderstood the whole aeration thing?
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    You are understanding it correctly.
