Thread: Foaming after adding bleach
    I am converting to chlorine and just started I've poured about 12 gallons of concentrated Clorox into the pool (21 foot diameter by 48inches high). When I'm getting is a lot of foam is this normal?
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,075
    Re: Foaming after adding bleach
    Quote Originally Posted by WCB430
    Oh yeah. Frothy sludge, like something out of a 1950s Horror B-movie.
    And why aren't you posting pictures of the technicolor pool changes for us to enjoy?
    Scroll through the Bac forum looking for threads with lots of replies and the paperclip icon that indicates pictures.
    Samantha_in_AL's Avatar
    Apr 2010
    Altoona, AL
    242
    I swear I saw smoke coming off my pool when I first started my Baq conversion. Don't let it scare you. Take lots of pics, we love to watch your progress.
    AG 18' X 52" Round Pacifica Pool w/ Metal Diamond Unibead Liner. Installed in March 2007.
    2.5 HP Baquapure 2 Speed Pump, 200 GPM Waterway ProClean Cartridge Filter System.
    Former Baquacil user
    Converted to BBB in Fall of 2009 - Now I have a truly trouble free pool!
    Yep the foam was pretty..the Chlorine is up to level based on the control strips..so I took a water sample to the store they tested it and quess what I STILL had B in solution:
    Total Cl=2.8
    free Cl= 2.8
    CYA=10
    ph=7
    total hardness= 73
    adj total alkalinity= 67
    ok I've got to raise the Alkalinity
    ph need to go down
    then I had them test for Softswim
    softswim b=24
    softswim c=0
    total hardness= 67
    adj total alkalinity= 97
    and the water is cloudly
    how do I get rid of the B stuff and why is the Alkalinity differnet....it the same water
    Bill
    Richard320's Avatar
    Jan 2010
    19,075
    I think the answer is Pool Store Testing.
    Check out the chart in this thread. inconsistency-in-readings-t61728.html
