Results 1 to 9 of 9
Thread: Can I live with a TA of around 150?
    Apr 2012
    Puglia, Italy
    133
    PH is currently 7.6. I understand that to lower TA I need to lower PH, however our fill water comes from a limestone water table, so I think I will be constantly increasing TA with every backwash and top up. Should I be constantly adding acid to get the TA down or can I just accept and live with it. I reckon the PH is going to keep going up, so I will have to add some acid anyway to keep it down to the recommended levels.
    400,000 Litre in ground infinity pool, with 40,000 litre holding tank (116 235.703 04 gallon). Vinyl liner.
    Two Astralpool Cantabric sand filters, 900mm diameter, each with 550kg of sand.
    Two ESI MP6 1.5kw 3 phase pumps.
    38,532
    Re: Can I live with a TA of around 150?
    Accept it and just keep the pH in range. The TA may drop some, but it is not critical to try to get lower if the fill water is high.
    Apr 2012
    Puglia, Italy
    133
    OK thanks. Calcium hardness is way up too, presumably for the same reason. Guess I will just have to live with that too.
    Butterfly's Avatar
    South Carolina
    10,045
    How high is CH?
    You're done SLAMing when:
    Apr 2012
    Puglia, Italy
    133
    around 500
    38,532
    That is livable. You just need to keep closer tabs on the pH to prevent calcium scaling.
    Only way to lower the CH is through water replacement with lower CH water.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,074
    No. Your skin will peel off and you'll die a slow, agonizing death.
    Just kidding!
    You have it figured. Maintain pH and TA will slowly come down. Keep tabs on things and if CSI starts to climb, then you might have to take aggressive action to lower TA. Instructions are in Pool School.
    Apr 2012
    Puglia, Italy
    133
    OK thanks, check the PH pretty much daily anyway, so just keep introducing acid to keep the PH within range?
    Mar 2007
    San Rafael, CA USA
    12,082
    Yes, just keep adding acid to keep the pH in range.
