Thread: Rain and Overnight FC loss test
    efm1972's Avatar
    Jul 2012
    Philadelphia, PA
    19
    Can rain (about 1") impact the Overnight FC loss test? If so, by how much?
    Test results on June 6th @ 6:45PM EDT (with Taylor test kit)
    FC = 17.5
    CC = 0
    Test results on June 7th @ 7AM EDT (with Taylor test kit)
    FC = 13
    CC = 0
    Thanks
    18,500 gallons, DE filter, IG
    Onyx Ansylbrite (colored) plaster
    Jandy Pump 1.0 HP, Zodiac Filter (flow rate = 120 gpm)
    Installed May 2012
    Butterfly's Avatar
    South Carolina
    10,045
    Re: Rain and Overnight FC loss test
    It could have had some effect w/stuff being blown into the pool, no way to say how much effect.
    It appears you need to redo the OCLT again tonight.
    You're done SLAMing when:
    efm1972's Avatar
    Jul 2012
    Philadelphia, PA
    19
    Thanks, I will. Hopefully the rain stops. It's been raining for about 24 hours now and I'm feeling soggy
    Installed May 2012
    Butterfly's Avatar
    South Carolina
    10,045
    Quote Originally Posted by efm1972
    Dang, sure hope the rain stops. No fun feeling soggy unless you are actually in the pool
