Results 1 to 7 of 7
Thread: Pop Tile repair - best practices?
    May 2011
    PA
    38
    I had a single little tile pop off at a skimmer entrance just above the regular water line. In-ground pool, tile is 2 years old. Leslie's said that regardless I should use their Patch-It to re-adhere it. Is that still the best practice?
    30,419
    Re: Pop Tile repair - best practices?
    Have no idea what the product is. You could stick it back on with some adhesive caulk.
    That said, don't be too surprised if some more (or that one) pop back off.
    May 2011
    PA
    38
    What type of caulk is best for this application?
    30,419
    polyurethane will probably give you the best adhesion. I would consider any caulk a temporary patch but you might get good use from it.
    May 2011
    PA
    38
    So isn't there a more "permanent" way to fix it? I.e., one that should last as long as the rest of the original tiles?
    30,419
    Yes, remove all the affected tiles, sand down the thinset, and retile and regrout. This is not a DIY job unless you have done quite a bit of tile.
    chiefwej's Avatar
    Jun 2011
    Tucson
    2,943
    I had pretty good success with my previous 40 year old pool. I just chipped off as much as I could of the old thinset and stuck the tiles back with some modified thinset. There are several types, I would suggest some research on the various products. It is basically a cement product that is mixed with adhesive. Most but not all use a polymer adhesive in the mix. Some are more sticky and better suited to pool use. I'm sorry but I don't recall the specific product, but some research should turn up a good choice.
    chiefwej
