Intex 26x52 Ultra build. Question about leveling.
Jun 9, 2012
6
I am replacing an 18x48 Summer Escapes pool with an Intex 26x52. As you can see from the pictures, I have the original spot where the old pool was then I marked a 22 foot line and a 26 foot line just for comparisons as I was curious to see the difference between the two. Any way 80 percent of my ground is level except where when you are looking at the pictures from the 12 o'clock to the 2 o'clock position(where the board is), that area is low by about 1-1/2" more towards the edges than in the middle. I already dug out the high spots and all of those areas are rock hard. My question is do you think it will be ok the build up an area that size? Should I concentrate on where the legs would be and be sure that it is compact? Also what type of material should I use to do it. I really don't want to dig down anymore. I'm exhausted from taking up the grass. Thanks in advance.
[attachment=2:3pcr5g3z]8978149724_ea6ffa201f_z.jpg[/attachment:3pcr5g3z]
[attachment=1:3pcr5g3z]8976959601_8c7d3cd5a3_z.jpg[/attachment:3pcr5g3z]
[attachment=0:3pcr5g3z]8978145462_cdb69c0f89_z.jpg[/attachment:3pcr5g3z]
