Results 1 to 9 of 9
Thread: Confusion about FC and TC levdl
    Jun 2010
    Dayton, Ohio
    241
    Ok this is probably a really dumb question. I have new k-2006 test kit and have actually gotten clear water in three days! Hooray! Still keeping FC at about 15 but I used old Walmart kit just to see what it would say and it's barely registering 5 in TC what in the world is that?? Am I crazy?
    AGP: 24' x 52" cartridge filter: 13,500 gallons. Taylor K-2006 test kit.
    Feb 2012
    Cypress, TX
    131
    Re: Confusion about FC and TC levdl
    What kind of test kit is it and how "old" is it? You have a good test kit so I would stick with that one and forget the old one. What readings are you getting from your good kit for TC. TC=FC+CC
    23x40 freeform w/spa, 28,000 gal. PCC-2000 in-floor cleaning. Pebble Sheen w/flagstone coping. 14' weeping wall, (2) 18" sheer descents. Sta Rite- cart 400 sqft. filter, Intellipro VS pump, 1hp (cleaning)2hp (water feature)Max E Pro's. Easy Touch 8 function w/IPod. Rainbow chlorinator, Paramount Clear O3 (I know, I know), Max-E-Therm 400K heater.
    Feb 2008
    Denton, TX
    5,061
    Your new Taylor kit is a far superior kit when compared to the other one. Stick with those values.
    Jun 2010
    Dayton, Ohio
    241
    My FC is 15 and CC is 0 the ild one is the Walmart HTH kit just thought it was bizarre.
    Feb 2012
    Cypress, TX
    131
    Those kind of test only read up to 5ppm. That's why the FAS-DPD test are recommended for higher levels of chlorine.
    Jun 2010
    Dayton, Ohio
    241
    I thought I had it so high it would be dark orange. Oh well. I will just stop messing with the old one!
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,075
    Quote Originally Posted by passionsrlz
    If the Walmart kit reads shades of yellow, then it should have gone orange.
    If it uses shades of pink, it might have bleached out from high FC. That's why the TF100 uses the yellow indicator tester.
    Jun 2010
    Dayton, Ohio
    241
    I shouldn't have played with old one because it has me confused. My new kit is showing me 15 FC. The Walmart one isn't turning dark orange and its worrying me. But I know to trust the better kit. I was just curious.
    30,432
    Throw it away and use a kit you can trust.
