Results 1 to 7 of 7
Thread: Good morning and hello to all!
    Jun 2013
    Smithfield, VA
    8
    My name is Leslie and I live in Smithfield, Va. I just purchased a 24' round AGP due to be installed on 06/22. I have no idea what I am getting into so I am sure that this site will soon become my best friend.
    24' X 52" 13,500gal AGP, 1.5hp Hayward pump, Hayward sand filter & 2013 Hayward Diver Dave (I call him Scuba Steve)
    22,548
    Re: Good morning and hello to all!
    Welcome to TFP.
    Feb 2008
    Denton, TX
    5,061
    Welcome to TFP!
    Butterfly's Avatar
    South Carolina
    10,045
    Welcome to the forum
    You're done SLAMing when:
    byteme's Avatar
    May 2013
    Marietta, Georgia
    41
    Greetings and welcome to TFP!
    As a new member, too, I can tell you that you will find the people here friendly, patient, knowledgeable and VERY helpful!
    A few suggestions I would offer you are:
    1. If you haven't already, get one of the recommended test kits and use it. They may seem expensive at first blush, but when you consider how much you'll save on chemicals and trips to the pool store, it will more than compensate for the cost of the kit. You must know what your pool is doing to successfully maintain it. The experts here need those test results to help you learn to properly maintain your pool and help you resolve any problems. When I first got mine, I was initially intimidated by it but, after using it a few times, it's really quite simple.
    2. Read Pool School. Read it again. Once you get your test kit and have used it a couple of times, read it again! Also, read even the topics you think don't really apply to your setup. You'll be surprised at the little tidbits of information you'll find!
    3. Browse the forums. There is TONS of great information available there!
    4. Ask questions! If you're unsure about something, ask. The folks here are more than willing to help you LEARN! Follow their advice and you'll find yourself confidently caring for your own pool in no time!
    13500 gal above ground (24' round/4' deep), vinyl, 2hp/2 speed pump, ProClean cartridge filter (125 sq ft surface area), Hayward auto chlorinator (turned off!).
    "There once was a fellow named Harry, who's pool became green and contrary!
    Then he found TroubleFree, learned about BBB, now pool care's not quite as scary!"
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,464
    WELCOME! You have found THE place to be when you have a pool!
    1st step-order a pool-done
    2nd step-order a GOOD test kit -see my siggy for a link to them.
    3ed step-jump into your pool and go awwwwwwwwwwwwwww
    Kim
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,988
    Welcome!
    Don't listen to your namesake or her minions at her pool store.
