Results 1 to 7 of 7
Thread: I Witnessed the Birth of a BBB'r!
    UN1017's Avatar
    May 2012
    Sacramento, CA
    288
    A friend of mine just finished his new pool (IG Pebble Sheen with all the bells and whistles). He hired all of his subcontractors and even did a lot of work himself.
    I asked him if he was going to do his own pool maintenance and he wasn't sure. I told him he can do it and I can give him some guidance. I sent him to a pool store to get the needed supplies for when his pool was filled. (Don't be nervous. Keep reading.)
    I had him get:
    - bleach
    - MA
    - stabilizer
    - pole
    - brush
    - and a TF-100 (yes....there is certain store that carries them in the Sac area)
    He told the clerk that he was new to the whole pool thing and was sent here to to get these items. He said the clerk was apprehensive to give him all the chemicals at first (understandable) until he uttered, "I also need a TF-100." It almost sounds like that was the secret password. They prepared his requested items and out the door he went.
    Fast forward to fill completion day. With Pebble Sheen startup procedures in hand, we did a hands-on version of Pool School and fired up the TF-100. I showed him how to test the pH, TA and CH. I introduced him to the Pool Calculator and had him make the appropriate adjustments.
    One thing I failed to mention.....I brought my SpeedStir along and now he wants one.
    It felt pretty good to help someone take control of their pool from the very start and give them knowledge to avoid future frustration and disappointment. Keep up the good work everyone!
    15'x30' IG - Roman-style - 14K - Pebble Fina Classico
    Filter: Jandy CL460 Pump: Jandy Stealth SHPF1.5 SWG: Jandy AquaPure 1400 Cleaner: Jandy RayVac Test Kit: TF-100 w/SpeedStir
    Chlorine/CYA Chart----Extended Test Kit Directions----SLAM
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Re: I Witnessed the Birth of a BBB'r!
    Sounds like you did good.
    Ike
    p.s. you should get him to join here, maybe he could be UN1791 that way we would all know who referred him
    30,432
    Nice work, 1017 It feels pretty nice to help someone out, huh?
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,074
    Yeah, get him on here!
    Butterfly's Avatar
    South Carolina
    10,045
    You're done SLAMing when:
    The speedstir rocks!
    32000 Gallon 18'X40' Rectangular Gunite pool. Pentair 60sqft DE filter. Electric heat pump. Aquamatic Pool Cover.
    UN1017's Avatar
    May 2012
    Sacramento, CA
    288
    Quote Originally Posted by Richard320
    For some reason I knew you going to want pics. Let me see what I can do.
    I guess I did more than witness the birth....I'm kind of his TFP daddy!
