Thread: What to add to a K-2005 test kit
    Feb 2013
    Goodyear (Phoenix), AZ
    9
    My pool builder included a Taylor K-2005 test kit with my new pool. I see that the K-2006 is recommended. Does anyone know what tests I may be missing with having the K-2005 instead of the K-2006. I'm assuming it will be cheaper to add what I need then buy a whole new test kit but if I need to do that please let me know. Any help is appreciated. Thanks!
    25,500K gal, IG, Cartridge, Pebble, Pentair Intelliflow 1800rpm/3450rpm
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: What to add to a K-2005 test kit
    It is missing the FAS-DPD chlorine test (not to be confused with the DPD chlorine test).
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,045
    This: http://tftestkits.net/FAS-DPD-Chlorine- ... t-p47.html
    You might as well add a speedstir now and save shipping when you order one later. No one who owns one regrets buying it.
    Feb 2013
    9
    Thanks for the suggestions, I'll order both. What is the difference between the DPD chlorine test I have now and the FAS-DPD is the difference that I can measure higher levels of FC?
    Feb 2008
    Denton, TX
    5,061
    Quote Originally Posted by milambr
    Correct.
    38,403
    And it is more accurate as you are counting drops to get a color change from pink to clear and not trying to match a shade of pink ... and it will measure the FC and CC separately.
