Thread: Arm and hammer clear balance?
    Jun 2013
    Up in the mountain, Laurentides, Quebec, CANADA
    23
    Does anyone know what could be the ingrediant in this new pool maintenancwe product by Arm And hammer?
    http://www.armandhammer.com/deodoriz...e-tablets.aspx
    24.5k gallons, IG, vinyl, 24 inches sand filter hydropro 063030 sf, hayward pump 1,5 hp c48m2n111b4q
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,000
    38,284
    Re: Arm and hammer clear balance?
    I think it is mostly just baking soda and something to raise the pH to counter the acidity of trichlor tablets.
    Probably not worth using for most members here.
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Mar 2007
    San Rafael, CA USA
    12,082
    We generally buy and use only those chemicals that are needed. So if you need to raise the TA, then you get pure baking soda. The clarifier in this specialized Arm & Hammer product is not normally needed. If one maintains the properly FC and CYA levels in their pool, then the pool should remain clear and not need any clarifier, assuming the pool has decent circulation and filtration.
