Results 1 to 7 of 7
Thread: Algae and other help....
    May 2012
    Aledo, TX
    6
    We have some unusual brown spots on our pool. I would think it was algae it isn't slimey and it doesn't brush off. Here are my numbers - the FCC is low because we didn't put any chlorine in it last night because it was storming.
    Ph 8.0
    FCC 1.5
    TA 150
    CH 175
    CYA less than 30
    I don't know what to attach first!
    thank you for any help!
    35000 gal; colored plaster; DE; hayward pump
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,966
    Re: Algae and other help....
    pH first. It should only take an hour or less to mix well and then you can raise FC.
    CYA can be adjusted all the while, as it takes a few days to dissolve. It gets tied up in a sock or nylon stocking and suspended in front of a return or dangled off some kind of float like an empty bleach bottle or a pool noodle. Don't just pour it in the skimmer. If you need to backwash, you'll lose it.
    As for the stain, post a picture.
    [center:3j5judum][/center:3j5judum]
    May 2012
    Aledo, TX
    6
    Green pool turned blue but now in trouble
    Mod alert: Please keep your posts about same subject in one thread...thanks
    We have a mesh cover that we use to protect our pool from the spring live oak 'droppings.' It was a swamp when we pulled it off last month. After weeks of pool school help and a lot of cleaning of the filter, the pool is clear. BUT now we have some brown patches. I would think it was algae but it isn't slimey and it doesn't rub off. I add 128 oz of 8% bleach each night and and about of quart of muratic acid every two days to low the PH. I know we aren't doing it 'right' yet. Here are my numbers. My FCC is low because we had a storm last night and I didn't add chlorine.
    What should we focus on???
    Ph 8.0
    FCC 1.5
    TA 150
    CH 175
    CYA less than 30
    May 2012
    Aledo, TX
    6
    I add 128 oz of 8% bleach each night and and about of quart of muratic acid every two days to low the PH. I know we aren't doing it 'right' yet. Should I be worried about the TA or the CH?
    Ph 8.0
    FCC 1.5
    TA 150
    CH 175
    CYA less than 30
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: Green pool turned blue but now in trouble
    What is your CC?
    I would bring the ph down to 7.2 then start the shocking process, and do the Overnight chlorine loss test (OCLT) to see where you are.
    May 2012
    Aledo, TX
    6
    what's cc?
    Richard320's Avatar
    Jan 2010
    18,966
    Quote Originally Posted by 2 days the day
    what's cc?
    Combined Chloramines. That's like halfway used up chlorine. pool-school/swimming_pool_definitions_abbreviations
    The blue-grey tint and the olive green patch all point to algae. The CC test will help confirm it.
