Thread: How's my numbers look?
    Ph. 8.1-4 Always needs muric acid
    FC. 9.5
    TA. 100
    CC. .5
    TC. 10
    CH. 280
    CYA. 40
    Salt. 2770
    TF100 kit
    Pool 7 months old
    15,500 gal, IG, Blue quartz gunite, Hayward - SWG, C4530 MicroBan filter,2 speed Tristar pump, 400k heater, Phantom Turbo cleaner, 36" edge fountain
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,988
    Re: How's my numbers look?
    With a SWG you want to raise CYA a little. Then you can also lower the % on the SWG and try to keep FC between 3 & 5. You know about the pH.
    pool-school/recommended_levels (your pool is considered Plaster)
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    New plaster will demand acid.
    I don't quite understand 8.1-4? but keep you ph down below 7.8.
    Since you have a swg, I would move your cya up 70 ppm. See: http://www.troublefreepool.com/pool-...ater_generator
    Thanks guys, I can't figure out the ph using blue test kit. Some where between 8.1 and 8.4 I add acid every week. Pool store says .......8.04
    30,415
    You need to get your pH down sooner rather than later. Regardless of how much acid it takes, you need to be in the 7's for pH....NEVER at 8.0 or above.
