Results 1 to 10 of 10
Thread: DE - Common Name
    Jul 2011
    West Monroe, La
    67
    DE - Common Name
    I am thinking about adding some DE to help clear up the dead algae - sand filter I have been shocking since sat and water is nice and blue still cloudy where do you buy it and is there a generic or common name for this stuff?
    27'x54" Matrix Resin - 200lb Pentair sand filter - 1.5hp Pentair optiflow 2 speed pump - Aquatrol SWG - Gorilla Pad
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    Re: DE - Common Name
    DE stands for Diatomaceous Earth. DE is actually the common name for this product. Around here, I've seen it at Home Depot, Walmart, and pool stores. Just make sure you get a product labeled for use in pool filters.
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Lowes also sells it around here in their pool section around $20 for a 24 pound box, I just bought some. Note pool DE and garden DE are processed differently, Pool DE is an inhalation hazard like silica dust, but garden DE is much lower hazard as it is heat treated and partly melted around the edges of the particles.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,075
    Techguy reported that Wal-Mart sells DE in a box called "Filter Aid".
    May 2013
    Long Island NY
    419
    I have been using it for the past 2 days and it works well, my dosage is about 2 cups and I end up having to backwash every 4 or 5 hrs. The dirty water that comes out is amazing. At the same time you can see the pool move from green to blue. I got mine at a pool store for $15 / 10 lbs.
    You won't use much. At night I cut down to 1 cup so I don't worry about building up pressure due to not being able to back wash.
    19,000 gal - Vinyl IG - Sand filter -1.5hp. - Taylor k 2006 - Loop Loc cover
    Jul 2011
    West Monroe, La
    67
    Thanks I am going to find some today.
    May 2013
    Long Island NY
    419
    Just make sure you get filter grade and not food grade DE. I don't know anything about the food grade, I just read somewhere there are 2 different grades.
    Jul 2011
    West Monroe, La
    67
    Started DE last night do u have to add more each time you backwash?
    Richard320's Avatar
    Jan 2010
    19,075
    Quote Originally Posted by swanny297
    Yes.
    May 2013
    Long Island NY
    419
    I'm on my 3 rd day and my water is now Gin clear from using DE. Of course the DE that went through the back wash cycle is now in my yard. LOL
    But it was well worth it. I quit using it now and will rely on my sand filter.
    Another thing I noticed is if you turn your light on at night with the pump running you can see the little dirt particals in the water and that's a good reference on how your DE is doing.
    No particals, stop using DE.
    You will also note DE comming back into the pool through the returns. No big deal, it settles to the bottom and you vacuum them up and get to use them again.
