Thread: Chlorine control
    Jun 2013
    southwestern PA
    2
    Chlorine control
    How frequently should I expect to add liquid chlorine? I get the chlorine in spec and have a chlorine feeder (I use bromine tablets), but in 2-3 days the chlorine level is zero.
    20K gal, IG vinyl, 300 sq ft cartridge filter (STA-RITE System 3 Model S7M120)
    Hayward Max-Flo XL 1.0 HP pump, Heat Siphon Heat Pump 3.25HP
    Hayward Auto Chlorine Feeder (Model CL-200), Baracuda Pool Cleaner,
    Pool Installed 1998
    techguy's Avatar
    Jul 2010
    Antelope, CA
    2,687
    Re: Chlorine control
    Once I get my pool dialed in, I add CL once per day.
    If you are using BR or CL tabs, what is your CYA (stabilizer) number?
    What are you using for a test kit?
    If you are using your LPS (local pool store) what chemicals are they using to test your water?
    -- Guy --
    38,507
    Welcome to TFP!!!
    So do you have a bromine pool or a chlorine pool? Generally you do not mix them.
    Normally liquid chlorine should be added every day as it is consumed by the sun and any organics in the water.
    This thread has some info:
    switch-to-bbb-from-bromine-t61763.html
    Jun 2013
    southwestern PA
    2
    I'm a new home/pool owner and I have an OTO test kit from the previous owner. It measures chlorine and bromine levels, and pH. He used bromine tablets in the feeder, so I continued that process. The stabilizer level was 30 a couple days ago when I had a water sample tested at the LPS. I know I need a better test kit to test and monitor the pool water. I plan on buying one of the kits recommended by troublefreepool.com.
    Pool Installed 1998
    38,507
    Honestly, I am not sure what to tell you since you are using bromine (I have no experience with it). Most members here use chlorine exclusively, but there are a few people that should know how to get you straightened out.
