Thread: Out with the "Blob', in with the metal frame!
    Got rid of my blob pool last fall, and snagged a 16X42 metal frame for this season! Assembly was nothing I didnt expect. Got the frame level within 3/4 inch, seems to work out well, no signs of distress.
    The thru-wall skimmer is nice, seals tight, as does the thru-wall pump outlet. Petroleum jelly keeps the surface sealed and lubricated when installing the outlet.
    Only got one day of swimming before afternoon storms got in the way. Having a few years of BBB method behind me, no problem! Water was a bit green from the hose - straight into shock mode! Rain dilution? Nail it with the bleach! Still working to get the chemistry just right, but the rains have me in Bleach Defense Mode until they stop a bit
    My tip for those with the thru-wall skimmer... it doesnt work well when the pool is overfilled. There are minimum and maximum fill marks on the skimmer face plate. I plan on selecting my permanent level within that range once the rains stop, and drilling a small hole at that level so the pool will automatically dump excess water. Otherwise, you open the pump vent which is slow and messy, and pull the pump exhaust hose for more speed and mess. With the hole, it will dribble it's way down to the perfect level wetting the yard no worse than the rain that caused the overfill.
    Many thanks to this board and the BBB folks! Without it and them, I'd be stuck in Science Project Mode!
    Butterfly's Avatar
    South Carolina
    10,045
    Re: Out with the "Blob', in with the metal frame!
    Alrighitie, now let see a pic
    You're done SLAMing when:
    OMG no, the backyard is a mess right now!
    When I do drill the "Water Auto Level Hole", I'll be sure to post a pic! A close-up!
    Butterfly's Avatar
    South Carolina
    10,045
    Quote Originally Posted by ob1quixote
    , okay, we'll wait
    mcoonan's Avatar
    Aug 2008
    Mendota Heights, MN
    292
    "Petroleum jelly keeps the surface sealed and lubricated when installing the outlet."
    No, no no! petroleum jelly will eat at your seals and the pool itself!
    You should be using a teflon/silicone lube. ( like this http://www.ebay.com/itm/Aladdin-Magi...item257ec8e850 )
    Intex Ultra 18' x 52" AG 6,981 Gal.
    3 - 2'x20' solar panels
    Hayward XStream 1500 Cart Filter
    Hayward 1-1/2 HP 2-speed Superpump
    Aquabot Pool Rover
    2-Softub 300 hot tubs (yup just got one for the lake)
    TF Test Kit Doing the BBB for 7 years
    Medota Heights,Minnesota
    Jul 2009
    S. California
    157
    Intex advises in their set-up instructions to add petroleum jelly to the thru wall fittings. I thought this was not a good idea for the rubber seals too, so I only put it on the threads to help the main nut tighten more smoothly. I did this for 4 years on my old Intex pool without incident.
    Congrats on upgrading from the "Blob" ! I too made the move this year and am thrilled with the new pool. Not to mention my kids who totally outgrew the old Easy Set pool.
    Enjoy!
    18'x 52" Intex Ultra Frame AG pool
    7100 gallons
    1600 Intex sand filter
    TF-100 test kit
    BBB method for four seasons
    Former 18' Easy Set owner
