Page 1 of 2 12 LastLast
Results 1 to 20 of 22
Thread: Come play 'what is this 2" pvc pipe in my yard?'
    Jan 2013
    The Great State of Texas
    243
    Hopefully I am about to ask the world's most stupid question and I will get an answer right away.
    I don't know if this pipe is pool related, house related, or some kind of septic thing. I just closed on the house a couple of months ago. Standard 3 br 2 bath slab foundation (rare to find a basement in Texas). I was starting to dig out a back bed along the house when I ran across what I thought was one of 12 million rocks strewn all over the place by a previous owner. I went to pick it up and realized it was a 2" pvc line cap. I dug out about a foot down but still have no idea what it is or where it is going. There is sand around it, which leads me to believe it was put there by someone who had a good idea what they were doing. The pipe is about 5 inches from the slab of the house. It is on the outside of the master bedroom, probably 10 feet from the nearest indoor plumbing fixture (which is located on the same outside wall, just 10' down the wall). On the outside of the house the next closest plumbing things are about 12" away. That would be a water faucet (run in the wall and exiting through the brick of the house). Also about 12" away is the pool equipment (20 year old pool). Just slightly further down at roughly 16" is the septic tank pump out and lid. The pipe has a cap on it that reads for a pressurized plumbing set up, but I haven't got enough of the pipe exposed to see if it shows for pressure. The cap doesn't seem to be a threaded cap like I have seen on clean outs. Looks like it was intended to stay on there.
    There are no pipes coming off of the pool equipment above ground and then heading underground besides the normal "from pool & to pool" lines which head in a different direction. There is an old polaris setup on the far side of the pump, but it was cut apart years ago and just part of the piping wasn't removed. I feel sure that it isn't part of that.
    So, here are some pictures. Please remember I haven't been in the house long and I am working on the "ugly". Also, when I laid sod a couple of weeks ago, I didn't unstack (I thought it was cool enough) and my 2nd pallet got burned in the center. I put it down anyway. It is coming back, but those burned pieces are ugly right now... so yep, there is that. I put a red shovel right at the pipe so you can see where it is a bit easier in the distance shots .
    So you can see the distance to the pool.
    From the pool equipment area back towards the mystery pipe.
    I know you are thinking "don't worry about it, just cover it back up and go on with your planting", but I am planning an outdoor kitchen and if I suddenly find out that I have septic tie ins run out there, it would make my life easier. Plus, I just don't like things that I don't understand.
    Thanks for any ideas that you might have! Like I said, it is probably something that I should have recognized at first glance.
    ~18,000 gallon
    DE filter/chlorine
    IG Grey Plaster
    25 year old pool w a facelift in 2014
    38,528
    Re: Come play 'what is this 2" pvc pipe in my yard?'
    Not a clue ... might want to keep digging and see what direction it is running. If it connects to a Y, then that would point to a cleanout ... but it is pretty small pipe for that.
    Jan 2013
    243
    I am going to go out in a bit and get another trowel so I can keep at it. Somehow my trowel was broken by "not me" the other day and I hadn't replaced it. The pipe is so close to the house that it is hard to dig at it. How deep down would the Y usually be? All my plumbing knowledge comes from a 100 year old house with a basement. It isn't a lot of use right now.
    ~18,000 gallon
    DE filter/chlorine
    IG Grey Plaster
    May 2012
    Oklahoma City, Okla
    14
    If it were me, I would first remove the cap. turn all the water on in the nearest bathroom and listen for running water at the top of the pipe.
    If you hear nothing, I would have some one flush while you again listen at the top of the pipe.
    I have not seen a clean out that small but, you never know what some people will do.
    Is there a french drain system around the perimeter of your home? Just a thought.
    Or is it possible that there was once a fountain/water feature in this location and this is the water source abandoned?
    Might want to check all you valves at the pool equipment since it is located close by.
    Good luck!
    Okalhoma City, Oklahoma
    TF-100 Test kit, BBB method
    20,000 gal ig vinyl liner, fg steps, ss ladder/rail, 14.5' x 42' x 4.5"
    Sta-Rite 37 sq ft DE filter, 1 1/2 hp pump, inline chlorinator, Sta-Rite 2" multiport, Polaris 145 cleaner.
    Jan 2013
    243
    After some more digging I feel sure that thing is headed straight back to the skimmer basket on the pool. I only see the one line. I have no idea what this could possibly be. Any ideas on that?
    ~18,000 gallon
    DE filter/chlorine
    IG Grey Plaster
    Pre-plumbed drain for an outdoor sink drain?
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,074
    Maybe it's an overflow from the skimmer leading to the sewer? And that was supposed to be the vent stack or something?
    May 2013
    North East Ohio
    959
    Mmm, could it be an auto fill line that was never connected to an auto fill device.
    My line looked a ton like that before it was finished.
    14,750 GAL IG Fiberglass (16 x 33) NE Ohio || Jandy 1HP 2 speed Pump || Waterco MultiCyclone 16 Centrifugal pre-filter (removed due to not working with sand filter) || 30" 575 Lb. Sand Filter || AquaCal 140K BTU Heat Pump || Solar Cover || Inter-fab Adrenaline Slide || GLI Monsoon Solar Cover Reel || K-2006C Test Kit || BBB with Liquid Chlorine Stenner Injection || Rayner Mighty Mesh Winter Cover
    For backwashing into the sewer?
    POOL: Intex ultra new in 2014 (32 x 16 x 52) (seasonal; on concrete pad covered with 1.5" extruded or whatever foam insulation sheets - ugly, but comfy); added a through-wall skimmer; I add salt for feel. EQUIPMENT: Pentair SuperFlo pump (1HP, 2SPD); Pentair cartridge filter (200 sq. ft); Pentair MasterTemp natural gas heater (400,000 btu) Climate/Location: Eastern Nebraska
    I'm guessing that's a cleanout of some type associated with your house plumbing. Though some folks who will remain nameless have theoretically hooked up their backwash drain to the sewer line...
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Update on this? A cleanout is usually 4" so it is puzzling...
    Essential Links:
    Jan 2013
    243
    I dug it out far enough to see that it is running back to the pool, right at the skimmer. I don't know if initially the pool equipment was located in this spot and then moved (doesn't really look like it- power doesn't seem to have been run to that area, but maybe it was all moved when pool equip was moved a bit further down house???). Or perhaps if there was some thought about putting in a spa close to the house but tying it to the pool? I really never did figure out what it was for except it really does seem to head to the pool and matches the size pipe used for the pool.
    ~18,000 gallon
    DE filter/chlorine
    IG Grey Plaster
    May 2013
    North East Ohio
    959
    Quote Originally Posted by glitter&guns
    AUTOFILL - once again this is exactly how mine is setup.
    I have a line coming off the skimmer and near the house I have 2" PVC plumbed into my autofill bucket.
    Of course I am guessing, but this makes total sense to me...unless others have better ideas
    Jan 2013
    243
    Quote Originally Posted by toofast
    I am such a noob, so forgive me for being stupid. Does your auto fill line then run to the pool equipment area or does it live off by itself? Also, is there a waterline located right where it comes out of the ground? I don't have any water over there. Also, does it just run into the pool/skimmer where you can see it, or does it run into the line headed to the pump? I can't see where this line goes into the pool or skimmer anywhere.
    ~18,000 gallon
    DE filter/chlorine
    IG Grey Plaster
    Jan 2013
    243
    Hey, would it be possible for auto fill to be coming up THROUGH the skimmer? My skimmer has 2 holes in it, but only one has suction. My main drain was cemented over years ago and several pool guys told me the main drain would have pumped up through the skimmer basket and headed out from there, but both thought it was odd that it wasn't plugged at the skimmer basket. BUT if there was an auto fill and it could have gone in through the bottom of the skimmer, that would explain it... also, this might be crazy talk, so don't make fun of me.
    ~18,000 gallon
    DE filter/chlorine
    IG Grey Plaster
    MiaOKC's Avatar
    Apr 2012
    Oklahoma City, OK
    347
    No idea, but thought I would comment that our 40 yr old pool has had the main drain capped and abandoned but we still have two holes in our skimmers - only one of them has suction, though. So it might not be all that uncommon. I have no idea what all the plumbing we have around our pool does, it is a rat's nest of plumbing running every which way, so I couldn't say if we'd ever had an auto-fill or not. We don't now, that's for sure.
    I'll look at our equipment pad, I feel like some of our abandoned plumbing looks capped like that but can't remember. Maybe it's an overflow for the main drain/skimmer tie in and since your main drain was disconnected they capped that off.
    35,000 gallon gunite pool, semi-T-shaped, 29x15 shallow end and 16x22 deep end, built in the mid-1970s and renovated 2013-2014 // Polaris 9300 Sport robotic cleaner // Taylor K-2006 ... Learning as we go and so grateful to everyone here for their help! Our reno thread
    May 2013
    North East Ohio
    959
    I am attaching a few pics so you can see my layout...once again, you original PB could have THOUGHT about an autofill, then decided against it, etc.
    Hope this helps!
    [attachment=2:b1uey5tm]autofill.jpg[/attachment:b1uey5tm]
    [attachment=1:b1uey5tm]autofill 1.jpg[/attachment:b1uey5tm]
    [attachment=0:b1uey5tm]autofill 2.jpg[/attachment:b1uey5tm]
    Jan 2013
    243
    Thanks Too Fast! You may have hit the nail on the head. It is an odd spot for a refill, but I could believe that is it. I figure that when I have a bit of muscle over, I will have him figure out how to get the cap off and we will see if we can figure anything else out. Buying a house is so interesting! lol!
    ~18,000 gallon
    DE filter/chlorine
    IG Grey Plaster
    It might go to a well point under the pool to control ground water in the event that you need to drain the pool.
    Can you contact the pool builder to ask them?
    Support the site
  20. Back To Top    #20
    Jan 2013
    243
    Quote Originally Posted by JamesW
    I did contact the pool builder when I bought the house, but without the name of the person that bought the pool and the year it was built, they couldn't tell me anything (Blue Haven... maybe not their best branch, either). I was hoping that they could bring their paperwork on the instillation and bid a remodel.
    That is a thought about the well point. I wonder if pool ground water wells would be common here? I think of this part of Texas as aching for water. The pool was empty when we were in the process of buying the house and there was no problem with water coming in, but the main drain is sealed, so maybe it wouldn't be a problem any longer?
    ~18,000 gallon
    DE filter/chlorine
    IG Grey Plaster
