Thread: Bronze Slide Push-Pull Valve Identification
    Looking to replace a backwash slide valve shaft.
    But I have no clue what the make or model is.
    I've scoured so many websites but I can't find a close match.
    Anyone recognize the logo / mark on the valve housing?
    Looks like two diamond-shaped stars...
    Any help would be most appreciated.
    BTW, this is an awesome looking active forum. I might have visit more often looking for tips.
    Backstory...
    Recently noticed water starting to leak around the slide valve.
    Was told by a Leslie's Pool employee to check the O-ring inside the backwash valve.
    Sure enough, it was worn and was likely causing the leak.
    I also noticed that the rims (?) that hold the center O-ring in place are decaying, contributing to the leak.
    22,553
    Re: Bronze Slide Push-Pull Valve Identification
    Back up a little and let us see the whole valve?
    I suspect you're going to be better off replacing the whole valve.
    Sure. Here are some more pics.
    Took it to a local pool supplier and they basically gave me a shrug and told me to it was too old/no longer manufactured.
    They didn't recognize the make either (or rather didn't even bother to examine it carefully.)
    This is just a long shot. I'll probably just break down and spring for whole replacement if needed.
    Couple more shots. Those washers were my lame attempt at salvaging the plunger.
