Thread: AquaLogicAQL -SWG Kit - Replace Turbo cell 15 with T-CELL-9*
    Hello All,
    This is my first post, I want to thank you all for all information I got from here.
    I bought my house last year. Since than my AqalLogic kit(http://www.hayward-pool.com/pdf/manu...stallation.pdf) shows Very low salt level, but every time I bring water sample to pool store for test, Test result shows salt within range of 3100 to 3500. I have been shocking pool by adding bleach as needed till now. Recently I started working on finding out why my SWG is not working, I cleaned it with muriatic acid solution and waited for couple of days and still system says very low salt level (1900). I think I need to replace CELL, My question is currently I have Turbo Cell 15 installed as a part of kit, Can I replace it with Turbo Cell 9 As my pool size is 17,300 gallon.
    38,547
    Re: AquaLogicAQL -SWG Kit - Replace Turbo cell 15 with T-CEL
    Depends on the software in your controller whether you can use the smaller cell. BUT, I would suggest sticking with the 15 as it should not have to work as hard and last longer.
    22,553
    I'm with JB, I'd stick with the 15.
    Have you had the cell tested? Some pool stores can do that.
    I will have it tested the cell this weekend. Most likely It needs to be replaced as I guess cell is 6 to 7 year old.
    What will be the procedure after I replace the cell to go from BBB to SWG?
    22,553
    There's really no formal conversion. Get the salt level correct and maintain the rest of the levels according to the TFP standard and then just switch on the swg and let it take over. Test and adjust as always. Just follow the outline for swg levels.
