Thread: In-ground Vs. Above-ground suction cleaners
    Jun 2008
    Duncan, Oklahoma
    2
    Can anyone tell me what is the difference between above-ground and in-ground suction cleaners?
    I am a new pool owner and I am looking to buy a suction cleaner, but I don't understand why the suction cleaners that say they are for above ground pools are half the price of "in-ground" cleaners. I want to get the right tool for the job, but at the same time I don't want to spend more than I have to if the functionality is the same.
    Thanks in advance for any advice or info.
    David from Oklahoma
    Generally the difference is that above ground cleaners are designed to run on a flat bottom, while in ground cleaners are designed to handle a sloped bottom.
    Guest
    In gound cleaners also will climb pool walls.
    Apr 2008
    Central Texas
    326
    Yep, my Polaris 280 (for inground) climbs all the way up to the coping many times during its run.
    26,000 Gallon Gunnite IGP
    2 HP Challenger High Head Pump
    60sf Nautilus DE filter
    Polaris 280
    Oct 2007
    Asheville, NC
    43
    I've been meaning to ask a similar question. I have an AG pool with a deep end. I assume I can't use the AG pool cleaners, because I don't have a flat bottom, but have wondered if I can use the IG pool cleaners.
    Johanna
    1984 vintage 16x32 Doughboy vinyl AG w/deep end, Sand Filter
