Thread: Measuring R-0870
    Measuring R-0870
    The exact amount of R-0870 powder used is not critical. The goal is to add more than you really need rather than using too little. Using too little R-0870 powder can throw off the results of the test. You need to use enough to bind to all of the chlorine that is present. Adding extra, within reason, has no effect. At very high FC levels it is likely that you will need to use more than the normal amount.
    Hello Jason,
    I just received my first Taylor K-2006 today and the little dipper appears to be broken. I'm assuming it should look like a miniature teaspoon, but mine is cut off. I was still able to load it with R-0870. based on your note above, do you think it's okay to trust it until a replacement arrives?
    18,000 gallons IG plaster pool
    cartridge filter
    2 speed pump
    Re: Measuring R-0870
    Sure, that will work for now.
    The little spoon does have one flat end and the other is a tiny, tiny "spoon." Here is a picture - just making sure yours is really defective.
    http://tftestkits.net/images/products/100.JPG
    POOL: Intex ultra new in 2014 (32 x 16 x 52) (seasonal; on concrete pad covered with 1.5" extruded or whatever foam insulation sheets - ugly, but comfy); added a through-wall skimmer; I add salt for feel. EQUIPMENT: Pentair SuperFlo pump (1HP, 2SPD); Pentair cartridge filter (200 sq. ft); Pentair MasterTemp natural gas heater (400,000 btu) Climate/Location: Eastern Nebraska
    Yep, mine has the flat end, and at the spoon end it looks like only half of the mold was filled during the manufacturing process. The seller is shipping me a fresh one tomorrow.
    Thanks for taking the time to respond with a picture!
    cartridge filter
    2 speed pump
