Thread: Chlorine
    I did my tests yesterday morning. For the first time, I got a CC reading of 1. My FC has been pretty stable around 4.5 for the past few weeks.
    Free CL - 4.5
    Comb CL - 1
    PH - 7.4
    Total Alk - 80
    CYA - 65
    I was worried about the CC so I tested again last night.
    This time, my FC was at 6 and my CC was 0-.5 (when I added the reagent the solution was very faint pink and cleared completely with one drop).
    Is a jump in FC normal? Is it normal for CC to lower on its own?
    The water is crystal clear and there was no rain or anything unusual yesterday.
    Chesterfield, MO
    In Ground vinyl liner pool
    - Lagoon Shape - 40'x30'x20'
    - Intelliflo VS Pump
    - Intellichlor Salt System
    - Triton II Sand Filter
    - Pentair MasterTemp Heater
    - EZ Touch Controller
    - Faux stone water feature with sheer descents
    - Turbo twister slide
    38,242
    Re: Chlorine
    CC is broken down by the sun or FC, so it fluctuates. 1ppm is a little higher than we like to see, you could just add bleach to temporarily boost the FC.
    When does your SWG run? If the second test was after the SWG had run all day, then it would be normal for the FC to rise some.
    Re: Chlorine
    It's running 24 hours a day right now. Is that not normal? Sorry, we are new pool owners.
    Chesterfield, MO
    38,242
    Re: Chlorine
    Depends how much money you want to spend on electricity:
    pool-school/pump_run_time
    Re: Chlorine
    Thanks. Up to this point, we've had a tree that's been dropping alot of **** into the pool so we've been running it quite a bit. The droppings from the tree have stalled, so we should be able to run it less or turn down the rpm on it. If I lower the rpm on the pump, do I need to up the % of chlorine from the SWG? Or is that just if I shut down the pump for a number of hours per day?
    Chesterfield, MO
    38,242
    Re: Chlorine
    As long as the pump is moving enough water for the SWG to operate ... it will make the same amount of FC regardless of the pump speed.
    If you shorten the pump run time (turn it off), then you may need to increase the % setting.
