Thread: Leslie's says chemistry perfect, still cloudy and green
    Chemical test
    FC 4
    TC 4
    Ph 7.4
    Alk TA 80
    CYA 40
    Calcium hardness 150
    Salt 3500
    Generation with cell is working fine for salt pool
    22,000 gallons. Vinyl
    Added clarifier clear and perfect. 6 oz
    Pool still green with gunk on bottom, brownish green, can't seems to vac it out, cartridge filters constantly fill up and I lose all flow and pressure, what do I do?
    38,539
    Re: Leslie's says chemistry perfect, still cloudy and green
    Welcome to TFP!!!
    If you have read anything here, you should likely be aware of how "highly" we feel about pool store testing.
    If you see algae in the pool you need to follow the Shocking Your Pool PROCESS using one of the Recommended Test Kits. This is also usually done with the SWG off. Once complete, you can raise the CYA to the the Recommended Levels.
    You should be cleaning the filters when the pressure rises 20-25% over the clean pressure ... this is be often when you have algae and one of the downsides of having a cartridge filter.
