Thread: need to replace spider gasket on multivalve
    Maryland
    22
    I have a pentair multivalve (261055)and need to replace the spider gasket. I have read different instructions and not sure what to do. Do I need to glue down the gasket with loctite 401 and if so do I glue just at certain points or the entire gasket. Once it is in should I lube the gasket.
    Thanks for any help
    IG, 32,000 Gallon, Plaster, 1HP Pentair Whisperflow, Pentair Triton II Sand Filter, Polaris 480
    30,427
    Re: need to replace spider gasket on multivalve
    More than one approach might be acceptable....I would certainly ask Pentair.
    Maryland
    22
    Tried to ask on the pentair site but no response in 2 days. Guess I might have to call. Was hoping someone here might know.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,043
    There are a couple how-to videos on youtube. Maybe they'll answer your question.
    Maryland
    22
    Talked to a Pentair tech rep a little bit ago and she said to use 4 or 5 dots of glue to hold the gasket in place and no lube needed on top of the gasket once installed.
