Page 1 of 4 1234 LastLast
Results 1 to 20 of 68
Thread: new intex pool owner
    hi!
    I have a 15x42in intex easy set pool. Filled it in a span of 3-4 days because i have a well. Did a test(HTH) today since its done filling and the levels were no
    FC:0
    PH: between 7.8 and 8.4
    TA: 180
    I have the HTH pop up pool start up and maintenance kit and want to know how to go about getting it swim ready.
    To me since the water came from our hose it should be fine to go in just add chlorine?
    Intex 15x42, 3284 gallons, AG vinyl, krystal clear/1000 gal/hr/Model#637R/ just bought second hand.
    38,429
    Re: new intex pool owner
    Welcome to TFP!!!
    You can add chlorine up to about 2ppm and be fine to swim, but chlorine will be gone in a few hours due to the sun breaking it down. You need to get some stabilizer in the pool to protect the chlorine.
    How are you intending to maintain chlorine in your pool? If you are unsure, I would greatly advise you to read Pool School (button at the upper right). Start with these:
    pool-school/pool_water_chemistry
    pool-school/types_chlorine_pool
    I have chlorine 1" blocks and the kit came with granuels of chlorine so one of the two. The kit also came with a chlorine stabilizer too. Can u swim after u put the stabilizer in? Also u think that one of the 1" chlorines would do the trick?
    msgtdan's Avatar
    Jul 2011
    SW MO
    653
    Dan D
    Used 2003 Aqua Leader 27'x52", 17,800 w/10" hopper, SwimPro SW256T 250# sand filter, Hayward PowerFlo LX pump 1hp impellor, Emerson 1 1/2 hp motor, setup Aug 2012 Summer 2011 used Summer Escapes Ring pool 14' x 42", Intex 1600gph sand filter, HTH 6 way test kitTF-100 w/stirrer, Well water @ FC=0, PH=7.2, TA=290, CH=320
    msgtdan's Avatar
    Jul 2011
    SW MO
    653
    Use http://www.thepoolcalculator.com/ to figure how much of what to add. Put your size pool at the top, select TFP and vinyl near the bottom and it will calculate what and how much you need. There is also a place at the bottom that can tell you what effect adding a certain chemical will have.
    Dan D
    hi the pool calculator doesnt seem to work for me. the numbers dont change even if i change the gallons :/ and its a pop up pool, which the post says you cant use the calculator for that kind. on a page where you can buy one it says it holds 3284 gallons
    38,429
    Where does it say you can not use the poolcalculator for a smaller pool? It works for any size pool.
    Just put the volume at the top, your current levels down the left column and your desired targets in the right column.
    With the pop up pools it says level will be off?
    38,429
    Quote Originally Posted by thevamplestat25
    Please define "it". I can not find what you are talking about anywhere on the poolcalculator.com website.
    Its the pool school link above
    38,429
    Oh. It just says that the pool volume calculator portion does not work well ... the chemical calculations will work fine.
    Oooo ok I thought the chemicals went by volume
    38,429
    They do. But you input your pools volume at the top. It is the part that estimates the volume based on dimensions you input that will not work well.
    Ooo ok thanks will do the calculator tomorrow and if I have prob will post here. Thanks for the help so far
    fc:0
    ph:8.4
    ta: 180
    38,429
    Was there a question there?
    I will add some for you:
    What is the CC? What is the CYA?
    What does the water look like?
    What test kit are you using?
    Why did you let the FC get to zero?
    pool cal says add 3.7oz of the cal-Hypo 48% (the shock 'n swim)
    I dont have anything to lower the PH
    I have stabilizer and conditioner (CYA)
    should i put the 3.7oz in first or the stabilizer and conditioner?
    FC was always 0, Im using the hth 4 way test strips only tests FC,PH, and TA, and bromine . water looks fine just leaves floating ect.
    i havnt put anything in the water yet so this is the test b4 adding stuff so i can use the pool cal to figure out what i need to put in.
    38,429
    Oh. Well why did you not say it was a fresh fill?
    First, realize that test strips are worthless. You would be much better off with the basic HTH 6-way kit you can find at Walmart (this is missing the FAS-DPD test, but your pool is small enough to just start over if things get out of whack).
    Are you not planning to follow this method?
    pool-school/temporary_pool_guide
    You are going to need some muriatic acid (or pH-) to lower the pH into the 7s, but you may want to confirm with the drop based kit first.
    If you are planning to add the CYA separately, then get that dissolving in the pool and get some FC in the pool ... you can do this now.
  20. Back To Top    #20
    hehe yes that method sounds good since its a pop up pool.
    can you put the cya and the fc in at the same time? bottles say not too. also the fc (shock and swim) says to do the PH stuff first. I would like to have something in the pool tonight to get it started then tomorrow run out get the test kit from walmart and the ph down
