Results 1 to 16 of 16
Thread: Pump or motor not working
    Hello all,
    I currently own a pool and decided to do maintenance myself. Ive been doing a good job so far. But last night the pump or motor stop working. I am not sure if it is the pump or motor that stop working... I know its 2 different things. But here is my situation. ..
    When I turn on the pump... i just here a humming noise as if the pump wants to turn on. But there is no water in the pump basket (not sure what is is called). Also the pressure to the D.E. filter reads 0. Does anyone have an idea of what this could be? I know replacing the pump is expensive and I dont want to go that route. Could it be clogged or something?
    35,000 gallon inground pool
    D.E. Filter
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: Pump or motor not working
    Welcome to TFP!
    There's a good chance that the capacitor has failed. They are common failures, but cheap to replace.
    What model pump do you have?
    Sorry I said there was no water in the pump basket and there is actually water in there... its just sitting there.
    NOt sure what model it is... the label says Century Centurion, Serial # BN10-137. Would that be the model?
    D.E. Filter
    Isaac-1's Avatar
    SW Louisiana
    6,711
    That is the motor, not the brand and model of the pump, perhaps you could post a photo
    I know it is a hayward pump not sure what the model is. I can post picture once I get home.
    If in my case the capacitor does needs to be replaced can I buy that at leslies pools or crown pools here in our local pool stores (Lancaster, Texas)? Or buy online? What website?
    Also, if my pool is overflowed would that be a reason for the pump to shut off?
    D.E. Filter
    Here is the picture of the pump.
    D.E. Filter
    SW Indiana
    9,199
    That is your multiport valve.
    Ok would this be the pump? Sorry im new to the pool world.
    D.E. Filter
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,058
    Quote Originally Posted by luria8
    Your picture doesn't show. For reference: http://www.troublefreepool.com/pool-...l_encyclopedia
    Scroll down to where it says Pumps.
    I edited my previous post with the picture.
    D.E. Filter
    Isaac-1's Avatar
    SW Louisiana
    6,711
    There are 2 pictures above one is your multi port valve, the other is a close up of the label on the pump motor. The pump is the rest of the thing around that label, as it is this is a bit like trying to identify a brand and model of car by a closeup shot of the license plate without having access to the DMV records.
    Thanks for your help! I will post a picture of the enite thing tomorrow... Sorry for all the confusion.
    D.E. Filter
    For those who were helping me... I ordered the capacitor from a local seller here in my area. My husband will be installing it today after work. I really hope this works. Sorry I didnt post a picture of the pump, but is was raining in the morning so I wasnt able to go outside. I will keep you all posted of the outcome.
    Thanks a bunch!
    D.E. Filter
    Great news! My pump is working like new!!! Thanks all for the help! It was such an easy fix!
    D.E. Filter
    Richard320's Avatar
    Jan 2010
    19,058
    SW Indiana
    9,199
