Thread: When to raise CYA?
    May 2013
    Southeast PA
    5
    When to raise CYA?
    Background:
    New pool owner, pool is about 30 yrs old. We used a pool service company to close (moved in at end of season) and open the pool and I would like to manage the pool going forward. Unfortunately, I was unsure of the exact chemicals and amounts used to open the pool on 6/1.
    Maintenance sheet from pool company on 6/1:
    FC: 3
    pH: 8+
    Alkalinity: 120
    Hardness: 260
    Stabilizer: 30
    Chemicals added (as noted on maintenance sheet):
    liquid chlorine: 5 gal
    pH Descreaser: 2 gal
    DE: 6 lbs
    On 6/4, used kit to determine presence of chlorine (1 FC & 1.5 CC) and pH (6.8). I added Borax and bleach according to the calculator to get a Shock FC = 10 and pH of 7.4. Unfortunately, I fell asleep before I could measure the chlorine.
    This mornings readings using TFT100:
    FC: 2.5
    CC: 3.0
    TC: 5.5
    pH: 7.4
    TA: 110
    CH: 340
    CYA: <20
    Based on these readings, I need to shock the pool (bleach) and perform the OCLT test. When should I add CYA? BTW, the pool water is clear and blue, not much different from when the cover was removed.
    22k gallon IG freeform plaster with Spa, A.O. Smith SQ1202 2HP Single Speed pump, Anthony VA-52 DE filter, Polaris 1-460-02 1HP Spa Blower, Raypak RP2100 400K, Caretaker 99
    Butterfly's Avatar
    South Carolina
    10,045
    Re: When to raise CYA?
    Welcome to the forum
    I suggest you raise CYA to about 30 for now. You can raise/fine tune CYA once the shock process is done.
    Congrats on your test kit and your knowledge
    You're done SLAMing when:
    May 2013
    Southeast PA
    5
    Thanks for the warm welcome and help.
