Thread: Help. Automatic way to add bleach into pool?
    May 2012
    Lexington, SC
    132
    So I am very busy with two children. I stay at home with them, but I have such a crazy schedule that I keep forgetting (and putting off) to add bleach to my pool every other day. I keep getting algae...my own fault, I know. Is there something sold out there that isn't outrageously priced that I can put in the pool or something to do this on a regular basis for me?
    Also, is there a polaris-type thing that will brush the pool? Like a robot brush or something? We finally got a polaris and we love it. What a good investment. And now I'm getting lazy and think it'd be great if I had something that would brush the pool for me too.
    13,500 gallons
    Sand filter
    IG
    TF-100
    22,553
    Re: Help. Automatic way to add bleach into pool?
    There are several things out there that will bleach to the pool. First off, have you conesidered a swg?
    If it's bleach delivery you want. There is the liquidator (LQ) that adds bleach whenever the pump runs. There is also injection pumps and tanks which can be ran with your main pump or be on a separate timer set to run some portion of the time the main pump runs. The LQ is about $180 and the Injection pump/tank is about $300.
    May 2012
    Lexington, SC
    132
    Thanks! i'll check into that liquidator thing. We did consider swg but I think we're going to stick with chlorine right now. Thanks for the info!
    13,500 gallons
    Sand filter
    IG
    TF-100
    harleysilo's Avatar
    Mar 2012
    North Georgia
    1,924
    Quote Originally Posted by DanaSC
    Just to be clear a SWG makes Chlorine from salt, so a "salt water pool" uses chlorine as it's sanitizer. Same chlorine as bleach/liquid chlorine/pucks etc.
    18'x43' Sport Pool
    19,000 Gallons Vinyl Liner 3'-3.5'-4'
    SWCG and D.E. Filter
    Test Kits - Pool Calculator - Chlorine/CYA Chart - Pool School
    Secret Weapon for Pool Chemistry Testing
    Butterfly's Avatar
    South Carolina
    10,045
    You're done SLAMing when:
