Thread: another help me wire my pump ????
    May 2012
    yuma AZ
    13
    Ok I have a 1hp pentair superflo 2 speed with toggle switch being wired to a dual intermatic timer t104106 heres my question my pump diagram shows 3 wires red to the board green to ground and black to the toggle but the diagram in my timer box shows 4 wires one to ground common (red) to #4 then one wire to high and one to low so do I need to add another wire if so to where or do i not because of the toggle and switch it manually thanks for any help I can take pics if needed
    15000 gal inground plaster 8ft deep kidney shape
    22,553
    Re: another help me wire my pump ????
    If you want the timers to start and stop the pump and switch the speeds then you need the 4th wire.
    Green to ground screw,
    L1 to term 1 on the T104
    L2 to term 3 on the T104
    Com from the pump to term 4 on the T104
    Low from pump to term 2 on the T106
    High from pump to term 3 on the T106
    A jumper from term 1 on the T106 to term 4 on the T106
    A jumper from term 1 on the T106 to term 2 on the T104
    May 2012
    yuma AZ
    13
    So if I do it this way do i leave the toggle hooked up or cap that line and hook to the board
    22,553
    Unhook the switch if you use the timer. You don't want the switch set one way and the timer the other.
    May 2012
    yuma AZ
    13
    Thanks shes up and runin
    22,553
